AccessViolationException with AeccPointImportOptions
dotela
dotela
I am working on an app in Vis Studio 2008 to bring a survey text file into a DWG. I am getting an error on the AeccPointImportOptions variable of the Points.ImportPoints function. This code I actually copied verbatim out of the civil_api_developers_guide.pdf p. 39. I get no compile errors, but get the error in the attached pic when the code runs.
Any ideas?
Based on your help file reference I'm guessing that this is in C3D2010. I
don't see anything wrong with the snip you've posted. The following small
test command, using the same sample code, executes without error here, so I
don't think there's a problem with the internal C3D code.
This is about all I've got at this time.
{code}
Imports System
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AECC.Interop
Imports Autodesk.AECC.Interop.Land
Imports Autodesk.AECC.Interop.UiLand
Public Class Class1
_
Public Sub TestMe()
Dim m_AcadApp As AcadApplication
m_AcadApp = Application.AcadApplication()
Dim m_oAeccApp As New AeccApplication()
m_oAeccApp.Init(m_AcadApp)
Dim oDocument As AeccDocument
oDocument = m_oAeccApp.ActiveDocument
ImportPointsfromFile(oDocument)
m_oAeccApp = Nothing
End Sub
Sub ImportPointsfromFile(ByVal oDocument As AeccDocument)
Dim oPoints As AeccPoints
Dim oImportOptions As New AeccPointImportOptions
Dim sFilename As String
Dim sFileFormat As String
Dim iCount As Integer
oPoints = oDocument.Points
sFilename = "C:\My Documents\SamplePointFile.txt"
sFileFormat = "PENZ (space delimited)"
oImportOptions.PointDuplicateResolution =
AeccPointDuplicateResolutionType.aeccPointDuplicateOverwrite
iCount = oPoints.ImportPoints(sFilename, sFileFormat,
oImportOptions)
' Export the files to a separate file.
Dim oExportOptions As New AeccPointExportOptions
sFilename = "C:\My Documents\SamplePointFile2.txt"
oExportOptions.ExpandCoordinateData = True
oPoints.ExportPoints(sFilename, sFileFormat, oExportOptions)
End Sub
End Class
{code}
"dotela" wrote in message news:6215484@discussion.autodesk.com...
> Any ideas?
