want to rotate structures with pipe network
goswami12897
Message 1 of 20
goswami12897
Hello I am developing small tool so I can swap multiple structural members at once but I want to align the replacing parts along with the direction of pipe too please can anyone help me how can I do that the code is below
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.DatabaseServices.Styles;
using System;
[assembly: CommandClass(typeof(SwapParts.Swap))]
namespace SwapParts
    public class Swap
        [CommandMethod("SwapAllParts")]
        public void SwapParts()
            Document document = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
            Database database = document.Database;
            Editor editor = document.Editor;
            editor.WriteMessage("\n Select the structures to replace");
            PromptSelectionResult solidSelected = editor.GetSelection();
            if (solidSelected.Status != PromptStatus.OK)
                editor.WriteMessage("\n Selected wrong Objects. Please restart the command to try again");
                return;
            SelectionSet set = solidSelected.Value;
            using (Transaction transaction = database.TransactionManager.StartTransaction())
                CivilDocument cDoc = CivilApplication.ActiveDocument;
                PartsListCollection partsListCollection = cDoc.Styles.PartsListSet;
                foreach (ObjectId part in partsListCollection)
                    PartsList partsList = transaction.GetObject(part, OpenMode.ForRead) as PartsList;
                        editor.WriteMessage($"\nPARTS LISTS: {partsList.Name}");
                    PromptStringOptions partsListName = new PromptStringOptions("\nSelect the Parts List from which you want to insert the new part")
                        AllowSpaces = true,
                    PromptResult partlistName1 = editor.GetString(partsListName);
                    string partsListName2 = partlistName1.StringResult;
                    ObjectId PartsList1 = cDoc.Styles.PartsListSet[partsListName2];
                    PartsList partsList2 = transaction.GetObject(PartsList1, OpenMode.ForWrite) as PartsList;
                    ObjectIdCollection partFamilyCollection = partsList2.GetPartFamilyIdsByDomain(DomainType.Structure);
                    foreach (ObjectId partStr in partFamilyCollection)
                        PartFamily partFamily1 = transaction.GetObject(partStr, OpenMode.ForWrite) as PartFamily;
                        if (partFamily1.Domain == DomainType.Structure)
                         editor.WriteMessage($"\nStructures: {partFamily1.Name}");
                PromptStringOptions partFamilyName = new PromptStringOptions("\nSelect the structure you want to swap these structures with")
                    AllowSpaces = true,
                PromptResult partFamilySwapping = editor.GetString(partFamilyName);
                string swapper = partFamilySwapping.StringResult;
                ObjectId structureId = partsList2[swapper];
                Structure structure = transaction.GetObject(structureId, OpenMode.ForWrite) as Structure;
                PartFamily str1 = transaction.GetObject(structureId, OpenMode.ForWrite) as PartFamily;
                ObjectId psizestr = str1[0];
                foreach (SelectedObject obj in set)
                    if (obj.ObjectId.ObjectClass.DxfName.Contains("STRUCTURE"))
                        Structure str = transaction.GetObject(obj.ObjectId, OpenMode.ForRead) as Structure;
                        str.SwapPartFamilyAndSize(structureId, psizestr);
                        string[] pipeNames = str.GetConnectedPipeNames();
                        if (pipeNames.Length > 1)
                            ObjectId pipedId = str.get_ConnectedPipe(1);
                            Pipe pipe = transaction.GetObject(pipedId, OpenMode.ForRead) as Pipe;
                        else
                            ObjectId pipedId = str.get_ConnectedPipe(0);
                transaction.Commit();
the part where the if else statement begins I tried to get angle the replacement tool works fine but unable to understand how to rotate the structures to align with pipe please help.
Replies (19)
Message 2 of 20
norman.yuan
Structure.Rotation property (read/write)? You just need to determine the rotation angle based on the connected pipe(s)
Norman Yuan
Drive CAD With Code
Message 3 of 20
goswami12897
exactly to what should I equate it to that's my doubt that it automatically takes direction of pipe
Message 4 of 20
goswami12897
I tried this but it is throwing the violation error and civil3d closes down please help me to rectify errors
                            Point3d pt1 = pipe.StartPoint;
                            Point3d pt2 = pipe.EndPoint;
                            double angle = Vector3d.XAxis.GetAngleTo(pt2 - pt1);
                            structure.Rotation = angle;
                        else
Message 5 of 20
hosneyalaa
@goswami12897
Can you attached example drawing
Message 6 of 20
goswami12897
Screenshot 2024-01-15 173336.pngScreenshot 2024-01-15 173233.pngLike here when I swapped null structure with the rectangular slab I want that slab to be aligned with the pipe following it basically in it's direction, I commented out the part that was causing violation and this much happened now I want to rotate the part too to align it with pipe following it and if it's the last pipe I want it to be aligned with the pipe preceding it
Message 7 of 20
goswami12897
basically all parts are coming in horizontal rotation ie 0 degees but I want them to be following the pipe rotation
Message 8 of 20
norman.yuan
Your code is a bit of confusing:
In the "if..." condition, you test "obj" is a Structure or not. If yes, you open it for READ, and assign it as variable "str" for calculating rotation. Then you set the rotation angle to another structure pointer "structure", which is declare outside the code scope you showed: it is the same Structure as the variable "str" points to? was it opened for write?
Norman Yuan
Drive CAD With Code
Message 9 of 20
goswami12897
one str is the structure that usee selected on screen, structure is fhe structure that is made on screen that swaps str
Message 10 of 20
norman.yuan
I do not understand your answer: shouldn't 2 structure variables point to the same structure (you only want to parsize to a different partsize (e.g the structure position is unchanged).
Also
What is the "structureId" in the SwapPartFamilyAndSize() call? Is it a partFamily's ObjectId? If yes, you have bad variable naming habit; if not (e.g., if it is a structure's ObjectId, as the variable name implies), that is one possible reason you get crash.
You should post more code to make sure how all variables are declared and objects are instantiated. Otherwise, I can only guess based on "common-sense" of variable names.
Norman Yuan
Drive CAD With Code
Message 11 of 20
goswami12897
so copy that code and comment out the line where Structure class variable was introduced, run it in civil3d it will throw an error that the objectid should be from structure class based on the commonsense I see. As I have already stated parts are getting swapped successfully I need help regarding rotation of the members, thank you.
Message 12 of 20
goswami12897
Whenever you put an objectid, you need to allocate the class as well right otherwise which objectid it is?
Message 13 of 20
hosneyalaa
@goswami12897
You do not need to the rotate , He takes it from the manhole before
Message 14 of 20
goswami12897
Yes that's true but some parts in the network are at  0 degree rotation from horizontal so have to get the rotation according to the pipe inlet
Message 15 of 20
goswami12897
@hosneyalaa is there any way we can get objectid's of the pipes connected to a structure or vice versa?
Message 16 of 20
hosneyalaa
Message 17 of 20
goswami12897
Hey the parts are successfully rotating now but when our angle of pipe in downwards in civil3D the rotation is not matching the pipe, can you tell me what could be done other then that it is spot on.
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Internal;
using System;
using System.Linq;
namespace SwapParts
    public class Swap
                return;
                        AllowSpaces = true,
                    AllowSpaces = true,
                        Structure str = transaction.GetObject(obj.ObjectId, OpenMode.ForWrite) as Structure;
                            foreach (string count in pipeNames)
                                editor.WriteMessage($"\n{count} ");
                            try
                                ObjectId pipeId = str.get_ConnectedPipe(1);
                                Pipe pipe = transaction.GetObject(pipeId, OpenMode.ForRead) as Pipe;
                                double angle = Vector3d.XAxis.GetAngleTo(pt2-pt1);
                                str.Rotation = angle;
                                editor.WriteMessage($"\n 2 pipes connected angle of Rotation : {angle:N3}");
                            catch (System.Exception exx)
                                editor.WriteMessage($"\n {exx}");
                        else
                            try
                                editor.WriteMessage($"\n 1 pipe connected angle of Rotation : {angle:N3}");
                            catch (System.Exception ex)
                                editor.WriteMessage($"{ex}");
like in these attached Screenshots if the pipes are coming in V shape it is fine but when opposite it is having error please check just some geometric correction required. Screenshot 2024-01-24 145152.png
Message 18 of 20
goswami12897
Message 19 of 20
hosneyalaa
TRY
                            //double angle = Vector3d.XAxis.GetAngleTo(pt2 - pt1);
                            double angle = Vector3d.XAxis.GetAngleTo(pt1.GetVectorTo(pt2), Vector3d.ZAxis);
                        else
Message 20 of 20
goswami12897
Thank you, it's working just flawless 💓
