VB.NET-DECLARATION STATEMENT
cturlington
cturlington
I am using Civil 3D 2016.
I am in the early stages of learning VB.NET and ACAD API.
I have a statement that I believe is legitimate but I am getting an error: "Declaration expected" with the blue squiggly underline.  However, just above the statement, I have the Dim statement that I believe should declare the variable.  A screen shots of the statement is attached for reference.  What am I likely missing in this statement that is causing the error?
augusto.goncalves
actually you should use:
public class ClassNameHere
<commandmethod("methodName")>
public sub methodName()
' your code here
end sub
end class
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
cturlington
Thanks Agusto,
That worked very well but I still got an "End of statement expected" at the end of the Public Class ValuesExample() with blue squiggly under the () at end of ValuesExample().  I have an End Class statement at the very end, following End Sub, as you indicated.  The error I am getting, I would think, suggests I forgot the End Class statement, but it is actually in place.  If I remove the () at end of Public Class, the error does not show  and all looks great.  Is that because I am not returning a value result ?
augusto.goncalves
there is no () on class declaration
public class ValuesExample
Augusto Goncalves
