Surface Label Text Component Referencing only a Single Point C3D 2026.1 Update Win 11 Pro
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a surface label that references 2 surfaces with the intent to show the grade for each surface from the same two points. The 1st component correctly labels the grade from one point to another. The 2nd Reference Text Surface component appears to label from a single point. The Grade <[Grade(P2|RN|AP|GC|UN|Sn|OF)]> option in the Text Component Editor is the one referencing the single point. How may I insert a component formula for the 2nd Reference Text/Surface to reference two points? In the attached you'll see the Surf 2 component only displays correctly if selecting the same surface. Both surfaces are identical and the label should display the same grade for each surface.
