Settung MH Floor Elev.
HPGarcia70
HPGarcia70
I'm fairly new to C3D.I need to set the floor of the MH to a designated elevation. I have the reference surface set. Where do I tell C3D the elev of the MH needs to be? I'm using 2014 if that helps.
Thanks in advance
-HP Garcia
C3D 2014
Ver:108.0.4, SP2
i7 3.40 GHz
32 G Ram
NVidia Quadro 200
Civil3DReminders_com
You will get more responses in the main Civil 3D discussion group (http://forums.autodesk.com/t5/autocad-civil-3d-general/bd-p/66) To get what you want, select the structure, right click and choose Structure Properties. In the list there will be a sump depth, this is the floor elevation value.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
