scaling a point style
I need some help with point styles
when the surveyor's pick up an existing tree this is the code as shown in the field book. The first code shows that the point is a deciduous tree with a diameter of 75mm. The second line shows the beginning and end of the dripline of the tree from the tree to the edge of the dripline of the tree
ZD VD 10282 125.361190 9653.739 55.348 "DEC 075"
BEG DRIPL1
ZD VD 10283 125.361188 9653.743 55.334 "DRIPL1"
ZD VD 10284 125.354321 9653.139 55.249 "DRIPL1"
END
The point style for DEC has a marker (Autocad Block) called called nf_tree_decid which has a circle where the trunk is and a pline around it where the dripline should be
this is the label style we created to include the diameter of the tree
<[Tree_Diameter(Umm|P0|RN|AP|GC|UN|Sn|OF)]>%%c
and there is a User-Defined Property Classification to allow you to enter the Tree Diamter,species
to make a long story short. We would like to be able to stretch the block of the tree to match the dripline and then change the circle (trunk) to match the diameter that was picked up in the field. With our currect setup we need to go in the properties and change the x-y scale in the geometry section to scale up the tree block but this also scales up the diamter at the same time
any help would be appreciated
