Removing Annotative from Object
my.yari90
my.yari90
Hello!
I've received a survey from surveyor and all the objects like Bollards, Light poles, Inlets... have annotative. Is there an easy way to remove them from the objects? That makes it hard to work with the actual size of the object!
Thanks!
Anton_Huizinga
Annotative is a property of the Block Definition and you could change it manually or with code. If it is a recurring problem you can change the symbols once and save the drawing as a template in which you insert the next survey.
But aren't symbols normally not used to indicate the type of an object and not to show true size geometry?
rgrainer
List an object (like you mentioned in your post) and tell us what it is called.
