Reconnect Gravity Pipes to Structures in Civil 3D (Dynamo or API Solution?)
i_syed7CYDV
i_syed7CYDV
Hello, everyone.
I am working on a Gravity Pipe Network (storm/sewer) in Civil 3D, and I have multiple locations where pipes are visually touching the manholes but are logically disconnected (Start/End Structure not assigned).
Since this issue exists in many locations, I would like to know:
Is there a way to reconnect all pipes to the nearest structures in one batch using:
  • Dynamo for Civil 3D, or
  • Civil 3D API / .NET plugin, or
  • any built-in command?
The pipe endpoints are already very close to the structures (within a small tolerance).
I am looking for a one-time automated solution instead of manually assigning start/end structures.
Any guidance or recommended workflow would be appreciated
I attached the drawing and highlighted those locations with circles
i_syed7CYDV
Any update please
Jeff_M
@i_syed7CYDV The .NET API has the Structure.ConnectToPipe Method which could be used to accomplish this task. I would loop through the Network's structures and pipes looking for those that are within a specific tolerance then connect if close.
Jeff_M, also a frequent Swamper
i_syed7CYDV
@Jeff_M
Thank you for the suggestion.
Would it be possible to share a simple sample code using Structure.ConnectToPipe with a tolerance check?
It would really help.
i_syed7CYDV
Any update please.
Jeff_M
@i_syed7CYDV I suggested what you can do, have you tried to create your own code using my suggestion? I had hand surgery and have no plans to do any code writing for sometime.
BlackBox_
@i_syed7CYDV - give this a try, so my partner @Jeff_M can heal:
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    Structure structure = (Structure)tr.GetObject(strId, OpenMode.ForWrite);
                    foreach (ObjectId ssId in ssIds)
                        Pipe pipe = (Pipe)tr.GetObject(ssId, OpenMode.ForRead);
                        if (pipe.ConnectedPartCount == 2)
                            ed.WriteMessage($"\nPipe \"{pipe.Name}\" is already connected at both ends, skipping.");
                            continue;
                        if (pipe.StartStructureId == strId || pipe.EndStructureId == strId)
                            ed.WriteMessage($"\n** Pipe \"{pipe.Name}\" is already connected to structure \"{structure.Name}\". ** ");
                            continue;
                        try
                            pipe.UpgradeOpen();
                            bool ok = true;
                            if (pipe.StartStructureId == ObjectId.Null)
                                ok = false;
                                structure.ConnectToPipe(pipe.ObjectId, ConnectorPositionType.Start);
                            if (ok)
                                structure.ConnectToPipe(pipe.ObjectId, ConnectorPositionType.End);
                            ed.WriteMessage($"\nConnected pipe \"{pipe.Name}\" to structure \"{structure.Name}\".");
                        catch (System.Exception ex)
                            ed.WriteMessage($"\n** Failed to connect pipe \"{pipe.Name}\" to structure \"{structure.Name}\": {ex.Message} **");
                    tr.Commit();
"How we think determines what we do, and what we do determines what we get."
Chris (BlackBox) Bradley
Managing Partner / Developer / Civil Designer
Quux Software | Sincpac C3D | Style Explorer
