Python cannot call table constructor (Dynamo Node)
triekGJKRK
Message 1 of 8
triekGJKRK
I want to create a table via python
https://help.autodesk.com/view/OARX/2024/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseSer...
I have the correct library in python to construct a table:
from Autodesk.AutoCAD.DatabaseServices import *
 But these commands both fail:
tbl = Autodesk.AutoCAD.DatabaseServices.Table()
tbl02 = Table()
Python Claims that it does not know what Autodesk is, and running the constructor alone it says there is no public constructor. All examples online say otherwise, I have tried running this Dynamo Python node via IronPython2/3 & Cpython3 to no avail. Any tips as what is wrong with my workspace? Thank you!
Replies (7)
Message 2 of 8
essam-salah
hi @triekGJKRK
do this instead:
import Autodesk.AutoCAD.DatabaseServices as acDb
myTable = acDb.Table()
Message 3 of 8
Norman_Yuan
@triekGJKRK  I can reproduce the issue you showed:
in spite of
tbl = Table()  causes error.
But once this line added, as @essam-salah suggested:
 and the table creating line changed to
tbl = acDb.Table()
the error is gone away and the Table entity can be created successfully.
However, this change (i.e. import Autodesk.AutoCAD.DatabaseServices as acDb) is not needed for creating other entities (DBText, Line...). Do not know why the Dynamo's python script interpreter could not recognize Table with "from Autodesk.AutoCAD.DatabaseServices import *" in place, yet it still recognize other entity classes. Maybe there are other few ones that would behave the same as Table, but with my limited Dynamo learning knowledge, I cannot say.
Norman Yuan
Drive CAD With Code
Message 4 of 8
triekGJKRK
I am so glad you said this I am not going crazy - yes I have noticed this behavior as well! I don't know what causes it but it's good to have this in writing, I should post this in the Dynamo forums!
Message 5 of 8
essam-salah
i always use full name (acDb.Line, acDb.DBText, ...) in my code, only for small scripts and and teaching snippets i write Line, DBText, but it is a rule of thumb to reduce ambiguity and run time errors is to use full name (acDb.Line not Line). specially for type like Table it's very common to be exist in other namespaces/modules.
import Autodesk.AutoCAD.Runtime as _AcRt              #type:ignore
import Autodesk.AutoCAD.ApplicationServices as _AcAp  #type:ignore
import Autodesk.AutoCAD.EditorInput as _AcEd          #type:ignore
import Autodesk.AutoCAD.DatabaseServices as _AcDb     #type:ignore
import Autodesk.AutoCAD.Geometry as _AcGe             #type:ignore
from Autodesk.AutoCAD.DatabaseServices import DxfCode as typeCode #type:ignore
# Import references from Civil3D
import Autodesk.Civil.ApplicationServices as _AccAp   #type:ignore
import Autodesk.Civil.DatabaseServices as _AccDb      #type:ignore
Message 6 of 8
Norman_Yuan
Very good tip. Thanks.
Update:
I just realized that since the boiler plate code Dynamo automatically added for the Python Script Node imports both Autodesk.AutoCAD.DatabaseServices and Autodesk.Civil.DatabaseServices:
from Autodesk.AutoCAD.Geometry import *
from Autodesk.Civil.ApplicationServices import *
from Autodesk.Civil.DatabaseServices import *
 therefore, create a namespace alias, as @essam-salah pointed out, is necessary, because both namespace has Table class, thus the error. Obviously, if the Python Script node only deals with AutoCAD, not Civil object, then removing "from Autodesk.Civil.Databases import *" would allow tbl = Table() work.
Norman Yuan
Drive CAD With Code
Message 7 of 8
triekGJKRK
@Norman_Yuan  This conversation exaclty, from your truly 😄 This is probably the more correct awnser I will set it as the correct one
Python Node - is the Table class exposed to python? - Civil 3D - Dynamo
Message 8 of 8
triekGJKRK
@essam-salah we have come to the core of the problem, which is that we imported two conflicting libraries. See the thread
