Projecting Objects to Profile Views
ebo134
ebo134
Hi guys
is there Projecting Objects to Profile Views possible in API, I mean if I want to project a cogo point to a profile View and Assign a label and style of it
is there a sample code?
thanks.
Please check this earlier post and associated sample code :
Projecting objects to profile in vb.net
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/Projecting-objects-to-profile-in-vb-net...
Partha
ebo134
thank you for your reply,
but it sounds its not dynamic label!! or its just an autocad point on model space with a text not projected object (Civil 3d)!!
correct me if Iam wrong, when you move your Profile View the Projected Objects should follow the parent Profile View.
It's not dynamic. This is kind of a work around.
FYI - We have an API wish list open to expose .NET API for projecting objects to Profile.
Partha
joantopo
Hi Partha.
taking advantage of this post, I would like that the API also contains the projectionObjectsCollection in a profileView class.
Other properties for a projectionObject should be: source type entity, source location, elevation type, station projected object, elevation projected object.
I want to do a command but I need the collection from each profile view, and I need to know the source location because I want to select an AutoCAD point in plant, show a datagrid within a form.
this datagrid will show all the avaiable profile views which contain it projected object and finally, according to the selected row in the dgv, the command will do zoom to the projected object in the selected profile view.
I think that Civil 3d would already have this function!
Moreover, the projection tab in the profile view is very poor.poor.ther is no information(only read) about:te station in case if the source object was Autocad point or COGO, source entity type, description.
That table should allow to be sorted such as by station .
and I think that the tab should be in a palette!
Regards.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
