The PressurePipeNetwork is what needs to be opened for write.
See quick example below:
<CommandMethod("PP_Merge")>
Public Sub CmdPP_Merge()
Dim aDoc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = aDoc.Database
Dim ed As Editor = aDoc.Editor
Dim opt1 As New PromptEntityOptions(vbCrLf & "Select First Pressure Part: ")
opt1.SetRejectMessage(vbCrLf & "Selected entity must be a Pressure Part. Try again.")
opt1.AddAllowedClass(GetType(PressurePart), False)
Dim res1 As PromptEntityResult = ed.GetEntity(opt1)
If res1.Status <> PromptStatus.OK Then Exit Sub
Dim opt2 As New PromptEntityOptions(vbCrLf & "Select Second Pressure Part: ")
opt2.SetRejectMessage(vbCrLf & "Selected entity must be a Pressure Part. Try again.")
opt2.AddAllowedClass(GetType(PressurePart), False)
Dim res2 As PromptEntityResult = ed.GetEntity(opt2)
If res2.Status <> PromptStatus.OK Then Exit Sub
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim pp1 As PressurePart = tr.GetObject(res1.ObjectId, OpenMode.ForRead)
Dim pp2 As PressurePart = tr.GetObject(res2.ObjectId, OpenMode.ForRead)
If pp1.NetworkId <> pp2.NetworkId Then
ed.WriteMessage(vbCrLf & "Selected parts must belong to the same network.")
Exit Sub
Dim network As PressurePipeNetwork = tr.GetObject(pp1.NetworkId, OpenMode.ForWrite)
Dim runs As PressurePipeRunCollection = network.PipeRuns
Dim run1 As PressurePipeRun = Nothing
Dim run2 As PressurePipeRun = Nothing
For Each run As PressurePipeRun In runs
If run.GetPartIds.Contains(pp1.ObjectId) Then
run1 = run
If run.GetPartIds.Contains(pp2.ObjectId) Then
run2 = run
Next
If run1 Is Nothing OrElse run2 Is Nothing Then
ed.WriteMessage(vbCrLf & "Error finding runs.")
Exit Sub
If run1.Name = run2.Name Then
ed.WriteMessage(vbCrLf & "Pipe runs cannot be the same.")
Exit Sub
Try
run1.Merge(run2)
Catch ex As Exception
ed.WriteMessage(vbCrLf & "Cannot merge pipe runs that are not connected.")
Exit Sub
End Try
ed.WriteMessage(vbCrLf & "Pipe runs have been merged.")
tr.Commit()
End Using
End Sub
If someone knows of a better way of getting the corresponding pipe run from the pressure part, please chime in. It seems to me that there should be a more direct way of getting the pipe run from the selected pressure part.
