Point Elevation Difference Lisp Routine
JBACH1012
Message 1 of 20
JBACH1012
I am trying to find a Lisp Routine that will allow me to select two Cogo Points and list the difference in elevation (z) in Inches with a Multileader. I have seen other posts on here about doing this but none seem to work for me. I have tried to Frankenstein a Lisp Routine from other posts but I do not know coding very well (see below). Any help on this matter will be greatly appreciated.
(defun c:ped ()
(setq Pt1 (ssget '((0 . "AECC_COGO_POINT"))))
(setq pt2 (ssget '((0 . "AECC_COGO_POINT"))))
(setq E1 (nth 0 Pt1))
(setq N1 (nth 1 Pt1))
(setq Z1 (nth 2 Pt1))
(setq E2 (nth 0 pt2))
(setq N2 (nth 1 pt2))
(setq Z2 (nth 2 pt2))
(princ (- z1 z2))
(command "_TEXT" pause "0.06" "0" (rtos (- z1 z2)))
;finish cleanly
);end of defun
John A. Bach Jr., CST II
High Definition Survey Manager
C3D 2024
Dell Precision 3660
Windows 11 Pro
128GB RAM
Replies (19)
Message 2 of 20
hosneyalaa
Message 3 of 20
JBACH1012
Thanks for the link but I am getting "Error: Automation Error. Problem in loading application" when I try to run it in Civil 3D 2021. It may be because this Lisp Routine was created in 2014.
C3D 2024
Dell Precision 3660
Windows 11 Pro
128GB RAM
Message 4 of 20
Jeff_M
@JBACH1012 attached is a lisp which does this. Be sure you have your desired Mleader style set current prior to running. It gives the option to select the points by Number or by Selection, it then will loop through as long as 2 points are provided.
Message 5 of 20
JBACH1012
Thank you! This works perfectly!
C3D 2024
Dell Precision 3660
Windows 11 Pro
128GB RAM
Message 6 of 20
albertluus2J23M
Community Visitor
Community Visitor
hi,
what is the command to use with this lisp.
Message 7 of 20
hosneyalaa
Hi @albertluus2J23M
Comment is PED
Message 8 of 20
qchenTPPXV
Thank you for sharing this. I have one question, Ithe file is loaded and I enter cogo but couldn't search for this commend. Any ideas for this? Thank you very much for your help!
Message 9 of 20
hippe013
The command name in the lisp that @Jeff_M posted is "PED".
Message 10 of 20
qchenTPPXV
Thanks. Do you know how to modify the result to round to 3 decimals. And delete the symbol after the number
Message 11 of 20
hippe013
Yes. You can do it though.
Look for the following code:
(rtos diff 4)
And modify it to be this:
(rtos diff 2 3)
Message 12 of 20
qchenTPPXV
Thank you very much for getting back to me. When I change to code, I get 3 decimals but the result is not correct.
[cid:db046cd7-f935-4df2-bf33-7382aee95d65]
Message 13 of 20
hippe013
It looks like he is multiplying the elevation difference by a factor of 12.
You can modify this block of code.
(setq diff (* 12 (- (last pt1) (last pt2)))
	  midpt (mapcar '(lambda (x y) (/ (+ x y) 2)) pt1 pt2);;for mleader inspt
	  inspt (getpoint midpt "...pick text insertion point: ")
	  mldrpts (list (car midpt)(cadr midpt) 0 (car inspt)(cadr inspt) 0)
	  ptlist (vlax-make-safearray vlax-vbdouble '(0 . 5))
          ptlist (vlax-safearray-fill ptlist mldrpts)
To be this:
(setq diff (- (last pt1) (last pt2))
Sorry, I should have caught that.
Message 14 of 20
qchenTPPXV
Thank you so much. It works perfectly now.
Message 15 of 20
Andrey_Goretoy
this LISP routine works perfect (with noted corrections) - thank you  hippe013 !  I am not a LISP programmer, but a constant user.  Would be nice if this Mleader would automatically pick 1st picked point as a start and the last picked point as a text inset location, so it kind of visually points which 2 points involved in calculation of a result that is displayed in Mleader, for example - see the screen clip below.  As of now - Mleader draws start leader point as MIDPOINT between 2 picked points (upper yellow arrow in inset) , and if points are close to each other - this is ok and will be well understood, but if they are far apart and some other points are around - it might be confusing.
Arrow pointer below is what I mean as it would be clearly pointing between two selected points exact locations.
Either way - this LISP routine is excellent!
Message 16 of 20
hippe013
@Andrey_Goretoy
The credit should really go to @Jeff_M I just helped with modifications.
To have the arrow be the first point instead of the midpoint is an easy modification.
Find this block of code, notice the midpt variable is being set to the mid between pt1 & pt2.
Remove the midpt assigning and replace its usage with pt1.
   inspt (getpoint pt1 "...pick text insertion point: ")
   mldrpts (list (car pt1)(cadr pt1) 0 (car inspt)(cadr inspt) 0)
I will leave it to you to modify and test.
Cheers! and Happy Coding!
Message 17 of 20
saqib_tipa
@Jeff_M
@hippe013
May you please modify this Lisp.
I want to subtract cogo point elevation from already existing 2-line Mtext. From 1st line it should take numeric value and subtract it from cogo point elevation and put it in 2nd line numeric values as replaced. (As in example picture).
If this is possible, I will be so thankful to you.
Thank you.
Message 18 of 20
MPD_TECH
Hey!
Thanks so much for all this work really helped me get my work done fast. I was wondering as well how would I go about making this metric (meters) and can I include spot elevations in the pick points?  Thanks again
Message 19 of 20
hosneyalaa
@MPD_TECH
Can you attached sample drawing
Message 20 of 20
MPD_TECH
Yes for sure, here is a screen shot of what I mean, essentially I have a bunch of slopes that runs perpendicular and need to show the diff in elevations, I've been doing them by hand with leaders.
