Pipes have a method called Project2dPointVertically (1). What does it do?
tcorey
Mentor Mentor
tcorey
Hmmm?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeff_M
@tcorey , Tim when you select a point on a pipe with GetPoint it returns a 3d point with 0 elevation. Using that point with the Project2dPointVertically it returns a 3d point with the correct elevation of the center of the pipe at that location. The help file for this method is incorrect, in that it says "surface" instead of "pipe".
That being said, i'm not sure if this method can be used in lisp. IIRC, this is one of those that lisp doesn't like the variants being passed. The .NET version of this works well, as that is what we used in the PipeElevationEditor in the Sincpac.
Jeff_M, also a frequent Swamper
