Pipe Structure PartSizeName returns wrong information
tipitasa
tipitasa
I'm trying to make a copy of a Structure, so I need to obtain the FamilyId and SizeId from the existing original Structure.
The PartSizeName that I read from the structure differs from anything that can be found in the PartSizes of the Structure PartFamily.
How do I get the correct match to obtain the SizeId from the existing Structure?
using Autodesk.Civil.DatabaseServices;
// structure that is used for the copy
Structure origStructure = tr.GetObject(origStructureId, OpenMode.ForWrite) as Structure;
Network existingNetwork = tr.GetObject(origStructure.NetworkId, OpenMode.ForRead) as Network;
PartsList networkPartsList = tr.GetObject(existingNetwork.PartsListId, OpenMode.ForRead) as PartsList;
// get structure family Id
ObjectId structureFamilyId = networkPartsList[origStructure.PartFamilyName];
PartFamily partFamily = tr.GetObject(structureFamilyId, OpenMode.ForRead) as PartFamily;
// traverse all part sizes in the part family to find size id
structureSizeId = ObjectId.Null;
for (int i = 0; i < partFamily.PartSizeCount; i++)
    PartSize partSize = tr.GetObject(partFamily[i], OpenMode.ForRead) as PartSize;
    if (partSize.Name == origStructure.PartSizeName)
        structureSizeId = partSize.Id;
        break;
Structure selection during network creation:
Result:
I have attacthed the basic file with two Pipe Networks.
Using Standard Network works OK, using Storm Network does not.
Moreover, this is possibly a silly question, but why cannot I peek into the Structure object in debug?
I open it normally:
Structure origStructure = tr.GetObject(origStructure, OpenMode.ForRead) as Structure;
And this is what I get:
What do I need to do to see the parameter values?
Norman_Yuan
A Part (Structure or Pipe) could have an "invalid" or "orphaned" PartSizeName, that is, the PartSizeName does not match any part in a PartFamily. It is usually caused by a updated/changed part catalog and/or the PartsList is updated, reimported...
 When this happens, you would expect user to change the PartSize to a valid PartSize available in the current PartsList. In the coding practice, it usually means that you would call Part.SwapPartFamilyAndSize() to apply an expected PartFamily/PartSize to the part. For example, you could check the drawing to see if there are structures/pipes with this unmatched PartSize; if found, you might want to present a UI to allow user to choose substitute PartSizes for the code to call SwapPartFamilyAndPartSize() method.
Norman Yuan
Drive CAD With Code
hippe013
It does seem strange that you are not able to peek inside the structure in debug.
Instead of...
Have you tried...
if (partSize.Name == origStructure.PartDescription)
tipitasa
I get this issue using a new document and a new Pipe Network. Can it happen that a PartSizeName is already invaild at creation time, or maybe that I'm not accessing the Parts List in the correct way?
tipitasa
I ended up using
if (partSize.Name == origStructure.Description)
as it seemed to always have the correct Part Size value.
