Mirrored SubAssembly disappear when calling an unrelated code
soonhui
Advisor Advisor
soonhui
Here's my code
        [CommandMethod(nameof(SubAssemblyCreationTest))]
        public void SubAssemblyCreationTest()
            var doc = Application.DocumentManager.MdiActiveDocument;
            using Transaction tr = doc.TransactionManager.StartTransaction();
            var assId = CivilApplication.ActiveDocument.AssemblyCollection.Add("Test", AssemblyType.UndividedCrownedRoad, Point3d.Origin);
            var baseLaneTemplateId = CivilApplication.ActiveDocument.SubassemblyCollection.ImportStockSubassembly("BaseLane", "Subassembly.BasicLane", Point3d.Origin);
            var shapeTrapezoidTemplateId = CivilApplication.ActiveDocument.SubassemblyCollection.ImportStockSubassembly("ShapeTrapezoidal", "Subassembly.ShapeTrapezoidal", Point3d.Origin);
           // var trapezoidTemplate = tr.GetObject(shapeTrapezoidTemplateId, OpenMode.ForWrite);  // uncomment this code will make the left half mirror assembly disappear
            var ass = assId.GetObject(OpenMode.ForWrite) as Assembly;
            var assemblyGroupRight = ass.AddSubassembly(baseLaneTemplateId);
            assemblyGroupRight.Name = "Right";
            var assemblyGroupLeft = ass.MirrorSubassembly(baseLaneTemplateId);
            assemblyGroupLeft.Name = "Left";
            var baseLaneTemplate = baseLaneTemplateId.GetObject(OpenMode.ForRead) as Subassembly;
            var baseLaneLeft = assemblyGroupLeft.GetSubassemblyIds()[0].GetObject(OpenMode.ForRead) as Subassembly;
            // Find Right Top Point
            var pt1 = (from x in baseLaneTemplate.Points
                orderby x.Offset descending, x.Elevation descending
                select x).First();
            // add Second Subassembly to Right Group
            if (pt1 != null)
                ass.AddSubassembly(shapeTrapezoidTemplateId, pt1);
            var pt2 = (from x in baseLaneLeft.Points
                select x).First();
            if (pt2 != null)
                ass.MirrorSubassembly(shapeTrapezoidTemplateId, pt2);
            tr.Commit();
When you run this, you will find that an assembly with a BasicLane and Trapezoid subassembly created symmetrically on the left and right side.
But if you uncomment the line
Then the left subassembly group disappears! But that line is an orphan line because we are not using it anywhere else.
That seems to me like a bug?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
  • Road
sreeparna_mandal
Civil 3D engineering team has confirmed that code fix for this issue will be available from C3D 2026.1 release.
