LispFunction - ExportTo Styles
I have some code I'm creating that exports some styles from one drawing to another. It works great a couple of times running it in the same drawing and then stops working. The stop working is that the code is gone through, returns to Civil 3D, but doesn't do the changes. It always makes it to the Commit() of the transaction.
Any ideas on what could be causing this? Do I have to open the drawing?
[LispFunction("CtStyleImport")]
public static ResultBuffer CtStyleImportCommand(ResultBuffer rbArgs)
// (CtStyleImport "C:\\Ct\\HQ\\C3D_2016\\Templates\\Ct_2016_Design_Other_Styles.dwt"
// (list "LabelStyles.AlignmentLabelStyles.StationOffsetLabelStyles" "CR Main FL TR_Left" "CR Local TRC FL Lip SW_Down")
// (list "AlignmentStyles" "CAiCE" "Align - Mainline [Analysis]")
// (list "GetSurveyLabelStyles().LineLabelStyles" "Standard")
// (CtStyleImport "C:\\Ct\\HQ\\C3D_2016\\Templates\\Ct_2016_Design_Other_Styles.dwt" (list "LabelStyles.AlignmentLabelStyles.StationOffsetLabelStyles" "CR Main FL TR_Left" "CR Local TRC FL Lip SW_Down")(list "AlignmentStyles" "CAiCE" "Align - Mainline [Analysis]")(list "GetSurveyLabelStyles().LineLabelStyles" "Standard"))
var rstBuffer = new ResultBuffer();
if (rbArgs == null)
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nNo objects passed");
var rbArgsList = rbArgs.AsArray().ToList();
try
var dwgPathAndName = rbArgsList[0].Value.ToString();
if (!File.Exists(dwgPathAndName))
rstBuffer.Add(new TypedValue((int)DxfCode.Text, "Drawing not found."));
return rstBuffer;
var civDoc = CivilApplication.ActiveDocument;
var doc = Application.DocumentManager.MdiActiveDocument;
var dbTo = doc.Database;
var ed = doc.Editor;
using (var tr = dbTo.TransactionManager.StartTransaction())
// civDoc.Styles.LabelStyles.GetSurveyLabelStyles().LineLabelStyles;
using (var fromDb = new Database(false, true))
fromDb.ReadDwgFile(dwgPathAndName, FileOpenMode.OpenForReadAndAllShare, true, "");
var civDocFrom = CivilDocument.GetCivilDocument(fromDb);
for (int i = 1; i < rbArgsList.Count(); i++)
if (rbArgsList[i].TypeCode == (int)LispDataType.ListBegin)
try
var styleColl = GetStyleCollection(rbArgsList, civDocFrom, i);
var styleNamesToTransfer = GetStyleNames(rbArgsList, ref i);
var styleObjIdsToTransfer = new ObjectIdCollection();
foreach (var styleName in styleNamesToTransfer)
if (styleColl.Contains(styleName))
styleObjIdsToTransfer.Add(styleColl[styleName]);
rstBuffer.Add(new TypedValue((int)DxfCode.Text, "Imported: " + styleName));
else
rstBuffer.Add(new TypedValue((int)DxfCode.Text, "Not Found: " + styleName));
StyleBase.ExportTo(styleObjIdsToTransfer, dbTo, StyleConflictResolverType.Override);
catch (System.Exception ex)
rstBuffer.Add(new TypedValue((int)DxfCode.Text, ex.Message));
tr.Commit();
return rstBuffer;
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
