Lisp to set waterdrop width
M_c3d
Advisor Advisor
Message 1 of 12
M_c3d
Hi All,
I'm trying to amend the waterdrop command to set the layer and width of the 2d polyline it creates.
The layer changes ok, but the plinewid variabe doesnt apply to the polyline created.
Any ideas?
Thanks in advance!
(command "_.undefine" "AeccCreateSurfaceWaterDrop")
(defun C:AeccCreateSurfaceWaterDrop () (setvar 'clayer "Surface Water Flow Path") (setvar 'plinewid 0.1) (command "_.AeccCreateSurfaceWaterDrop"))
Replies (11)
Message 2 of 12
Jeff_M
This should do it.
(defun C:AeccCreateSurfaceWaterDrop (/ PLINE plines lastent)
  (setq lastent (entlast))
  (while (= 1 (getvar 'cmdactive))
    (command PAUSE)
    (if (/= (entlast) lastent)
      (setq plines (cons (entlast) plines))
  (foreach ent plines
    (setq pline (vlax-ename->vla-object ent))
    (vla-put-constantwidth pline 0.1)
    (vla-put-layer pline "Surface Water Flow Path")
  (princ)
Jeff_M, also a frequent Swamper
Message 3 of 12
M_c3d
Hi @Jeff_M
Thanks for your help, it comes up with the error noted below.  The layer for the polyline created hasn't changed.
Command: AECCCREATESURFACEWATERDROP
Surface: Surface1 (1)
Select point:
Select point:
Command: ; error: ActiveX Server returned the error: unknown name: ConstantWidth
Message 4 of 12
Jeff_M
What C3D version are you using? I tested this in C3D 2018 and it worked well.
Message 5 of 12
M_c3d
r2021
Message 6 of 12
Jeff_M
Add the line (vl-load-com) to the start of the lisp. Also, I changed the code I posted above to add the plines and lastent variables to the locals list.
Message 7 of 12
M_c3d
It still comes up with the error;
Just to check, current lisp below;
(vl-load-com)
(defun C:AeccCreateSurfaceWaterDrop (/ PLINE)
(command PAUSE)
(foreach ent plines
(princ)
Message 8 of 12
Jeff_M
Strange. I just tested it in C3D 2021 and it works fine. Wait, looks like you have the Waterdrop tool creating 3d polylines. The default is 2d. 3dPolys do not have a width property. This accounts for either a 2d or 3d poly.
(defun C:AeccCreateSurfaceWaterDrop (/ PLINE LASTENT PLINES)
    (command PAUSE)
  (foreach ent plines
    (if (/= "AcDb3dPolyline" (vla-get-objectname pline))
  (princ)
Message 9 of 12
M_c3d
Hi @Jeff_M I still couldn't get it to work.
I did a reset of civil 3d and then added the lisp to the acaddoc.lsp file and suddenly it now works brilliantly! Not sure why it needed a reset.
Thanks, appreciate your help
Message 10 of 12
M_c3d
Hi @Jeff_M
I've noticed that it sometimes leaves some of the flow paths as they were rather than changing the layer and width.  Any ideas?  I've attached a gif of it.
Message 11 of 12
Jeff_M
Yes, I noticed that as well. I'm looking into it now.
Message 12 of 12
Jeff_M
@M_c3d here is a version that checks for the existence of the desired layer, creates it if needed, sets the C3D command setting for the waterdrop layer, creates the plines, then correctly changes the width of the plines.
(vl-load-com)
(defun C:AeccCreateSurfaceWaterDrop (/ PLINE LASTENT c3d c3ddoc surfsetting dwg layer layername)
  (setq layername "Surface Water Flow Path")
  (if (not (tblsearch "Layer" layername))
    (progn
      (setq dwg (vla-get-activedocument (vlax-get-acad-object)))
      (setq layer (vla-add (vla-get-layers dwg) layername))
      (vla-put-color layer 4)
      ;;here you can set the layer color and linetype
  (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
			     (if vlax-user-product-key
			       (vlax-user-product-key)
			       (vlax-product-key)
		 C3D (vl-registry-read C3D "Release")
		 C3D (substr C3D
			     1
			     (vl-string-search
			       C3D
			       (+ (vl-string-search "." C3D) 1)
		 C3D (vla-getinterfaceobject
		       (strcat "AeccXUiLand.AeccApplication." C3D)
  (setq C3Ddoc (vla-get-activedocument C3D))
  (setq surfsetting (vlax-get (vlax-get (vlax-get c3ddoc 'settings) 'surfacecommandssettings) 'createsurfacewaterdropsettings))
  (vlax-put (vlax-get surfsetting 'pathlayer) 'value layername)
    (command PAUSE)
  (while (setq lastent (entnext lastent))
    (setq pline (vlax-ename->vla-object lastent))
  (princ)
