LISP that would redraw sample lines with polylines.
ca20
ca20
Could You please help me with lisp that would allow me to export sample lines with their station values by:
- redrawig all existing sample lines (AECC_SAMPLE_LINE) with either lines or polylines;
- adding value of every sample lines „Station” property to corresponding polylinesThickness” property;
- adding wordSampleLine” to each polyline „Hyperlink” property;
That’s because „Thickness” and „Hyperlink” properties are easily accessible through MAPEXPORT command for lines / polylines, so I could rename them during export and continue to work with such .shp in different apps. I wasn’t able to find any workaround to export Sample Lines with their „Stations”, and this is complicating my workflow a lot, so any help would be much appreciated.
Jeff_M
This lisp should do the trick. Polylines are created on the current layer. Load the lisp, run the command SAMPLES2POLYS, select a sample line in the group to process, done.
(defun c:samples2polys (/ doc ms obj grp verts polyverts pline)
  (if (setq ss (ssget":S" '((0 . "AECC_SAMPLE_LINE"))))
    (progn
      (setq doc (vla-get-activedocument (vlax-get-acad-object)))
      (setq ms (vla-get-modelspace doc))
      (setq obj (vlax-ename->vla-object (ssname ss 0)))
      (setq grp (vlax-get obj 'parent))
      (setq idx -1)
      (vlax-for sl (vlax-get grp 'samplelines)
	(setq verts (vlax-get sl 'vertices))
	(setq polyverts '())
	(vlax-for v verts
	  (setq x (vlax-get v 'location))
	  (setq polyverts (append polyverts (list (car x) (cadr x))))
	(setq pline (vlax-invoke ms 'addlightweightpolyline polyverts))
	(vla-put-thickness pline (vlax-get sl 'station))
	(vla-add (vla-get-hyperlinks pline) "Sample Line")
  (princ)
Jeff_M, also a frequent Swamper
ca20
This code does exactly what it was supposed to, and fits perfectly into my workflow. Thank You so much Jeff, You just saved hours of my work.
