Lisp Routine for setting The pipe network catalog
ChilesConsulting
Message 1 of 23
ChilesConsulting
Can some take a look at this for me and tell me what I am doing wrong.
;;** Sets the Path for Pipes **
(setq pipecatpath1 (vla-registry-read "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R19.1\\ACAD-D000:409\\Profiles\\<<C3D_Imperial>>\\Preferences\\AeccUiNetwork100\\16C49365-B844-484b-92CE-9A8ACE681B57))
(if (/= pipecatpath1 "C:\\ProgramData\\Autodesk\\C3D 2014\\enu\\Pipes Catalog\\US Imperial Pipes\\US Imperial Pipes.apc")
(vla-registry-write "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R19.1\\ACAD-D000:409\\Profiles\\<<C3D_Imperial>>\\Preferences\\AeccUiNetwork100\\16C49365-B844-484b-92CE-9A8ACE681B57"
"pipecatpath1" "L:\\Resource Library\\Cad\STANDARDS\\Civ\\Pipes_Catalog\\US Imperial Pipes\\US Imperial Pipes.apc")
;;** Sets the Path for Structures **
(setq pipecatpath2 (vl-registry-read "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R19.1\\ACAD-D000:409\\Profiles\\<<C3D_Imperial>>\\Preferences\\AeccUiNetwork100\\DCE203A2-D381-466f-A23E-08A9D9F8FDBD))
(if (/= pipecatpath2 "C:\\ProgramData\\Autodesk\\C3D 2014\\enu\\Pipes Catalog\\US Imperial Pipes\\US Imperial Structures.apc")
(vl-registry-write "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R19.1\\ACAD-D000:409\\Profiles\\<<C3D_Imperial>>\\Preferences\\AeccUiNetwork100\\DCE203A2-D381-466f-A23E-08A9D9F8FDBD"
"pipecatpath2" "L:\\Resource Library\\Cad\STANDARDS\\Civ\\Pipes_Catalog\\US Imperial Pipes\\US Imperial Structures.apc")
Replies (22)
Message 21 of 23
redtransitconsultants
Could it be that the Metric folders aren't in there at all? Just thinking out of the box a bit... sometimes if things don't work properly I try to go back to the default structure Autodesk had and start from there to resolve the issue.
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Message 22 of 23
C3DJAKE
SetPipeNetworkCatalogDialogue.PNGSetPipeNetworkCatalogDialogueDrop.pngI added the Metric folders back to Pipe Catalog folder, but no luck! The default is still blank.
Might be time to start the folder over again, as you suggested...
Message 23 of 23
cyberflow
@redtransitconsultants & @C3DJAKE :
Funny thing, i'm looking to find out why my C3D leaves me blanks when i open that Set pipe network catalog settings
Did you folks found any reasons why it doesn't show the correct catalog selected ?
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
