Lisp commands need to be exported as NWCOUT.
ishaq.syed7CX2A
ishaq.syed7CX2A
Because I have a lot of CAD objects like lines, polylines, and block ets, I'd like to export only 3D elements from Civil3D, but can we make a list like pipes, structures, fittings, and appurtenances to export only 3D elements from Civil3D software as a NWCOUT using any Lisp command or any other option?  Please guide me if it's possible.
ishaq.syed7CX2A
Any update regarding the below subject is appreciated.
ftatulli
My suggestion would it be to share your C3D objects in Data Shortcuts. Then you load your objects in an empty file and from this file you can perform NWCOUT without all the other stuff you have in your work file.
The link is dynamic so you don't need to do anything beside from opening the export file.
I'm trying myself to come up with a method that doesn't involve to create a new file just for the export.
I'd like to have smething similar to a view template just like you can do in Revit but i need to figure out a way to quickly turn off all the layers of the objects I don't want to be exported.
