InsertLoopAt method of a Hatch
tcorey
Mentor Mentor
tcorey
Hello geniuses,
A hatch object has a method called InsertLoopAt (3). Does anyone have a reference  for this method? I can't figure out what it's asking for. I am giving it points and am getting a mismatch error.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
TerryDotson
I've never used that, but I do remember that hatch creation code require operations somewhat in a particular order, more restrictive than you would think.   This being a generic AutoCAD .NET related item, you would be better off searching and posting in that forum.
https://forums.autodesk.com/t5/net/bd-p/152
Jeff_M
@tcorey Tim, I'm guessing you are asking about doing this in lisp. The ActiveX docs has an example of using this method here:
https://help.autodesk.com/view/OARX/2020/ENU/?guid=GUID-E35E3387-14E8-433D-B6A6-82E034A11BEE
I'm not sure why many of the lisp lines of code are commented out, but it should help.
Jeff_M, also a frequent Swamper
tcorey
Thanks, @Jeff_M . I will try to figure it out from what you linked. My goal is to be able to select text objects and have them added as Islands in an existing Hatch.
Tim Corey
Redding, CA
Jeff_M
@tcorey Use the AppendInnerLoop method:
(setq hatch (vl-sel));;just a helper routine to entsel an object and convert to vla-object
(setq txt (vl-sel))
(setq innerLoop1 (vlax-make-safearray vlax-vbObject '(0 . 0)))
(vlax-safearray-put-element innerLoop1 0 txt)
(vla-AppendInnerLoop hatch innerLoop1)
(vla-Evaluate hatch)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-Regen doc :vlax-true)
