Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
I need a LISP file that outputs the design speeds of an alignment
Shubz26
Shubz26
I need a LISP file that outputs the design speeds of an alignment with start and end chainages. How can I do this? The LISP below takes me up to "Count=2", but no actual values.
(vl-load-com)
(setq e (car (entsel)))
(setq vlaobj (vlax-ename->vla-object e))
(setq CX1 (vlax-get-property vlaobj 'DesignSpeeds))
(vlax-dump-object CX1)
Civil 3D 2020
Intel Xeon CPU W3550 @ 3.07GHz
Nvidia Quadro 2000
25GB RAM
Windows 7 Enterprise 64 Bit
Jeff_M
You are close to having what you need. Just loop through the DesignSpeeds:
(vlax-for ds cx1
  (princ (strcat "\nStation: " (rtos (vlax-get ds 'Station)) "  Speed: " (rtos (vlax-get ds 'value))))
Note: If you add a t to the dump object function it will also list the methods available.
(vlax-dump-object CX1 t)
Jeff_M, also a frequent Swamper
Shubz26
Thanks!
I eventually figured out that I needed to loop through the Items. I found a way to do it in another code I found online:
(vl-load-com)
(vlax-for for-item
(vlax-get vlaobj 'DesignSpeeds)
(vlax-dump-object for-item))
Civil 3D 2020
Nvidia Quadro 2000
25GB RAM
