How to specify the default (Pressure|Gravity) Network when I create a Table?
soonhui
Advisor Advisor
soonhui
Refer to here, the screenshot is replicated below:
I can specify the table style via @Jeff_M  C# code, per below
  var settings = CivilApplication.ActiveDocument.Settings.GetSettings<SettingsCmdAddAppurtTable>();
            settings.TableCreation.TableStyle.Value= "Valve Name Size Type";
But what about the selected Network?
Anyway to specify that?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
Jeff_M
I don't believe there is a 'default' network. What I see is that it always has the first network selected and I must change it to the one I need.
Jeff_M, also a frequent Swamper
soonhui
@Jeff_M , so essentially you are saying that there is no API way to select the network in the above dialog box?
Ngu Soon Hui
Jeff_M
Correct @soonhui
soonhui
I've filed an equivalent request at the Ideas forum, please consider go and upvote it.
Ngu Soon Hui
