How to how to make Selection Set filter for Cogo Points (DXF Codes)?
I'm learning about programming for AutoCAD in VB.NET and still kinda new to things.
I was wondering how to develop a Selection Set Filter that will select only Cogo Points? I know I need to use Dxf.Start as the code, but then what's the string associated with Cogo Points? Can't find any documentation on this or any Civil 3D-unique entities...I know Line is just "Line" and "Arc" is just arc...but Polyline is the unintuitive "LWPolyline" and "Cogo Point" isn't working...
Jeff_M
To determine the string needed for items, create one in a drawing, select it, then LIST it:
Command: li
LIST 1 found
AECC_COGO_POINT <<<<<<<<<<<This is the DXF Object Name
Layer: "C-SITE-SIDEWALK"
Space: Model space
Handle = 51eb9
Jeff_M, also a frequent Swamper
BOOM! Knew there had to be some simple place to look. Thanks!
peterfunkautodesk
Instead of doing it with a selection set filter, look a the PromptEntityOptions object and the "AddAllowedClass" method. This is a really easy to limit the objects that can be selected. You can add the "SetRejectMessage" as well to give feedback when entities of the wrong type are selected.
Here are the lines in C#
PromptEntityOptions peo = newPromptEntityOptions("Select a COGO Point");
peo.AddAllowedClass(typeof(Autodesk.Civil.DatabaseServices.CogoPoint), true);
Cheers,
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Peter, does that work if I am doing a selection by window polygon?
Jeff_M
Yes, that works great for single entity picks, Peter. But for a selection set, still need to use the SSFilters.
