how to create structures ( pipe network) using .net (C#)
or_levi5LSMC
or_levi5LSMC
hey,
im pretty new to the civil3d automation, and i need to find a way to create new structures from data that i got from survey.
i looked in the api documentation, and saw only one example of how to create a pipe network using VB. (was not very clear)
if i understand correctly, to create structures , i need to first create new pipe network, and then i should use one of 2 overloaded methods of Netowork.AddStructure: which is specific to add new structure..
AddStructure(ObjectId, ObjectId, Point3d, Double, ObjectId, Boolean)
can someone help me with code example of how to start?
Aravinth.Pichamani
// add structure by cogo points
[CommandMethod("AddStrbyPoint")]
public void AddStrPoints()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Database db = doc.Database;
    CivilDocument Cdoc = CivilApplication.ActiveDocument;
    Editor editor = doc.Editor;
    try
        using (Transaction tr = db.TransactionManager.StartTransaction())
            ObjectIdCollection getpipeNetworks = Cdoc.GetPipeNetworkIds();
            foreach (ObjectId id in getpipeNetworks)
                Network network = tr.GetObject(id, OpenMode.ForWrite) as Network;
                // Get the Partlist from civil 3d dwg
                Var partlistColl = Cdoc.Styles.PartsListSet.Cast<ObjectId>().Select(p => p.GetObject(OpenMode.ForRead) as PartsList).ToList();
                // select part list from the listed partlist
                PartsList Selectpartlist = partlistColl.Where(p => p.Name).First();
                // Get the part Partfamily from selected partlist
                List<PartFamily> partfamilyCollecStr = Selectpartlist.GetPartFamilyIdsByDomain(DomainType.Structure).Cast<ObjectId>().Select(p => p.GetObject(OpenMode.ForRead) as PartFamily).ToList();
                PartFamily SelectedPartFamliyStr = partfamilyCollecStr.Where(p => p.Name).First();
                foreach (var partfamily in partfamilyCollecStr)
                    Structure strFamliySizes = tr.GetObject(partfamily, OpenMode.ForWrite) as Structure;
                    // if u have multiple point create list point 3d
                    Point3d point3D = new Point3d()
                // create str by point
                ObjectId Addstrbypoit = network.AddStructure(point3D, SelectedPartFamliyStr, strFamliySizes)
            tr.Commit();
    catch (System.Exception ex)
        editor.WriteMessage("Error {}", ex.Message);
Aravinth.Pichamani
Note: This is just an example. You can modify it further.
or_levi5LSMC
Hey aravinth,
thanks for your comment!
i tried running the script you have provided, and i saw that the
has 0 elements in it so i needed to loop on something else. so i looped over the partlist.
thanks to your general direction, i could create the following script that loops over mock data of manholes and create structures:
using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using Autodesk.Civil.DatabaseServices.Styles;
using ModifyStructure;
[assembly: CommandClass(typeof(Civil3DCommands.PipeNetworkCreator))]
namespace Civil3DCommands
    public class PipeNetworkCreator
        private string NETWORK_NAME = "MyPipeNetwork";
        [CommandMethod("makeStructure")]
        public void CreatePipeNetworkWithStructure()
            Editor ed = doc.Editor;
            CivilDocument civilDoc = CivilDocument.GetCivilDocument(db);
                try
                    ObjectId networkId = Network.Create(civilDoc, ref NETWORK_NAME);
                    Network network = tr.GetObject(networkId, OpenMode.ForWrite) as Network;
                    ObjectId partsListId = civilDoc.Styles.PartsListSet[0]; // Automatically selects the first parts list
                    PartsList partsList = tr.GetObject(partsListId, OpenMode.ForRead) as PartsList;
                    ed.WriteMessage($"\nUsing Parts List: {partsList.Name}");
                    // Get all families in the Parts List
                    int partFamilyCount = partsList.PartFamilyCount;
                    ObjectId structureFamilyId = ObjectId.Null;
                    PartFamily structureFamily = null;
                    // mock data- will be replaced by function that loops over the json and fill up the list->
                    List<Manhole> manholes = new List<Manhole>
                        new Manhole(89, "Circular", "Sewer", 0.12, 0.0, 0.0, "Concrete", 0.07, "Cylinder", 0.0, 0.0, 270, false),
                        new Manhole(1, "Ractangular", "storm", 0.0, 1.36, 0.48, "Steel", 0.61, "Ractangular", 1.42, 1.52, 90, false)
                    foreach (var manhole in manholes)
                        for (int i = 0; i < partFamilyCount; i++)
                            ObjectId familyId = partsList[i]; // Get the PartFamily ObjectId
                            PartFamily family = tr.GetObject(familyId, OpenMode.ForRead) as PartFamily;
                            if (family != null && family.PartType == PartType.StructJunction) // Ensure it's a Structure
                                structureFamilyId = familyId;
                                ed.WriteMessage($"\nUsing Structure Family: {family.Name}");
                                if (structureFamilyId == ObjectId.Null)
                                    ed.WriteMessage("\nError: No Structure Family found in Parts List.");
                                    return;
                                structureFamily = tr.GetObject(structureFamilyId, OpenMode.ForWrite) as PartFamily;
                                if (structureFamily != null)
                                    if (manhole.coverShape == "Ractangular" && structureFamily.BoundingShape.ToString() == "Box")
                                        break;
                                    else if (manhole.coverShape == "Circular" && structureFamily.BoundingShape.ToString() == "Cylinder")
                                        break;
                        ObjectId structureSizeId = structureFamily[0];
                        Point3d location = new Point3d(50 + manhole.id * 10, 50, 0); // Example location logic
                        double rotation = 0;
                        ObjectId newStructureId = ObjectId.Null;
                        network.AddStructure(structureFamilyId, structureSizeId, location, rotation, ref newStructureId, true);
                    ed.WriteMessage("\nPipe Network and Structures Created Successfully.");
                    tr.Commit();
                    ed.WriteMessage($"\nError: {ex.Message}");
norman.yuan
It looks to me that you missed one step: after creating the new Network and before adding Structures/Pipes to the it, you should assign a PartsList to the network.
Norman Yuan
Drive CAD With Code
