How remove spaces?
How remove spaces?
mehdi-guida
Message 1 of 10
How remove spaces?
mehdi-guida
Hi, I created line table(below image). Bearings are created by below codes and are dynamic.
How can I remove spaces in Bearing values? ('N 18d15'28" E'    to   'N18d15'28"E' )
and how can I change 'd' to '°' ?
lines_table.SetTextString(i + 2, 1, "%<\\AcObjProp Object(%<\\_ObjId " + lineid.Angle \\f \"%au4\">%");
Replies (9)
Message 2 of 10
hippe013
Select your table and right click and select "Edit Table Style"
Select the appropriate column and double click to bring up the Text Component Editor
Select DDMMSS.SS and then click the arrow to send it over ->
I hope this helps.
EDIT: Sorry, I misspoke. You will want to select the short name under the direction row.
Message 3 of 10
mehdi-guida
Thank you for reply. But I need to know what changes in my code can remove spaces automatically. I know the manual method.
Message 4 of 10
hippe013
Here is a quick example of setting the Direction ColumnStyle of a TableStyle to Short Name without spaces.
Where "res" is my PromptEntityResult and civDb is the Import Abbreviation to avoid conflicts with Autodesk.AutoCAD.DatabaseServices
Imports civDb = Autodesk.Civil.DatabaseServices
Using tr As Transaction = db.TransactionManager.StartTransaction
   'Get the Parcel Segment Table
   Dim tbl As civDb.ParcelSegmentTable = tr.GetObject(res.ObjectId, OpenMode.ForRead)
   'Get the TableStyle
   Dim style As civDb.Styles.TableStyle = tr.GetObject(tbl.StyleId, OpenMode.ForWrite)
   'In my Style the Direction Column is the Third Column.
   Dim dirStyle As ColumnStyle = style.ColumnStyles(2)
   'DSn is the Direction Short Name witout Spaces
   Dim format As String = "<[Segment Direction(Udeg|FDMSd|MB|P6|RN|DSn|CU|AP|EN|DZN|OF)]>"
   dirStyle.ContentStringFormatted = format
   'Commit Transaction
   tr.Commit()
End Using
Message 5 of 10
Jeff_M
@hippe013 Evidently @mehdi-guida is using plain Acad tables and filling them in with Fields, with the direction formatted to Surveyor units. I don't believe those units are editable.
@mehdi-guida Why not use an actual C3D table?
Message 6 of 10
mehdi-guida
Do you know how can create Civil3d line table by .Net(c#)?
Message 7 of 10
Jeff_M
As of C3D 2024, the only way would be to use SendStringToExecute and pass the native C3D command. I've not tried this so don't have any sample code.
Message 8 of 10
mehdi-guida
Unfortunately I am beginner in .NET.
Would you please help me to use SendStringToExecute for me below code?
TypedValue[] filterlist3 = new TypedValue[2];
filterlist3[0] = new TypedValue(0, "AECC_GENERAL_SEGMENT_LABEL");
filterlist3[1] = new TypedValue(8, "CR" + crnum2);
SelectionFilter filter3 = new SelectionFilter(filterlist3);
PromptSelectionResult Promptentity3 = ed.SelectAll(filter3);
SelectionSet label_selection = Promptentity3.Value;
Point3d viewctr = (Point3d)Application.TryGetSystemVariable("viewctr");
All the labels are in a selectionSet named ' label_selection'
and 'viewctr' is my insertion point of civil3d line table.
how can I use SendStringToExecute to insert c3d line table?
Thank You
Message 9 of 10
Jeff_M
@mehdi-guida as I said, this is not something I had tried. I just looked into it further and it appears the SendString ToExecute isn't the answer since the command to create the table brings up the dialog box and does not use a current selection to populate the labels to use.
I suggest checking the C3D Ideas board to see if there is an idea already submitted for creating table, add one if there isn't.
Message 10 of 10
hosneyalaa
Hi @mehdi-guida
I believe You can't get the text value from AECC_GENERAL_SEGMENT_LABEL
So you have to explod the items
Search in the forum you will Find the subject of  get the text value
