Google Earth Import - Invalid Pointer/Fatal Error
Matt__W
Advisor Advisor
Matt__W
I've tried to import a surface from GE; no dice.
I've tride to import a terrain from GE; no dice.
I don't have admin rights on this PC... I had to have one of the IT guys install it. Also, my application data information is stored on a network server which I have full read-write access. However, whenever I start GE, I get a message about it not being to create the Application Data\Google\GoogleEarth directory. Also, when I try to import either an Image or an Image & Surface, I get an Invalid Pointer error message. When I try to import just the surface, I get a fatal error after this...
Command: _ImportGESurface
DWG Coordinate System: NAD83 Connecticut State Plane Zone, US Foot
Use coordinate system for surface location or [Image] :
Then the CREATE SURFACE dialog box comes up, I pick a surface style, and then everything goes downhill from there.
Any ideas on how I can fix this? And no, having full admin rights on my computer is not going to happen - not if the IT guys have their ways.
Matt W
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Matt__W
Yes... I just realized I posted in the wrong group. I'll repost in the other group. Sorry.
Matt W
Matt Wunch
Twitter | LinkedIn
