Get vertex from volume surface.
joantopo
Mentor Mentor
joantopo
Civil 3D API has "TinSurfaceVertex" class and "GridSurfaceVertex" class.
I use those to get vertex:
  foreach (GridSurfaceVertex vertice in GridSurface.Vertices)
                           Autodesk.AutoCAD.Geometry.Point3d punt = new Autodesk.AutoCAD.Geometry.Point3d(vertice.Location.X, vertice.Location.Y, vertice.Location.Z);
                           pt3dColl.Add(punt);
 But TinVolumeSurface or GridVolumeSurface don´t have  neither "TinVolumeSurfaceVertex"  or "GridVolumeSurfaceVertex".
Are there other ways to get vertex from these surface types?
Thank you.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
Looks like these are missing...
I have logged an API wish list to expose these API in .NET
Partha
joantopo
Thank you.
