Get selection point via .NET?
Sinc
Advisor Advisor
Sinc
How do I get the selection point or pick point in the .NET API? That is, when the user picks an object, how do I get the coordinates that the cursor was at when the user selected the object?
I'm guessing it has something to do with the PickPointSelectedObject class, but I'm having difficulty figuring out how all this fits together with the Editor GetSelection method et al...
Sinc
You mean this?
PromptEntityResult res = ed.GetEntity("\nSelect Polyline: ");
Point3d pickPt = res.PickedPoint;
Or, if you mean to get the result ala the lisp function "ssnamex", I haven't
seen a way to do that...yet
"sinc" wrote in message news:5725332@discussion.autodesk.com...
The equal to ssnamex is found in the SelectedObject item of the
SelectionSet.
From the SelectedObject you can get the ObjectID, SelectionMethod,
SelectionDetails.
HTH.
"Jeff Mishler" wrote in message
news:5725395@discussion.autodesk.com...
You mean this?
Sinc
Ah, I was trying to use the ed.GetSelection() method and the PromptSelectionResult. There is no PickedPoint method with that.
I believe the PromptEntityResult will work. Thanks.
Sinc
