Get Pipe and Structure Tables via API
soonhui
Advisor Advisor
soonhui
It does seem that there is no way to get the Pipe and Structure Table via API? Let alone creating one via C#. Alas some other tables are available though, eg:
      [CommandMethod(nameof(GetTables))]
      public void GetTables()
          var doc = CivilApplication.ActiveDocument;
          // the below code works
          GetAllTables(doc.GetAlignmentTableIds());
          GetAllTables(doc.GetLegendTableIds());
          GetAllTables(doc.GetParcelSegmentTableIds());
          GetAllTables(doc.GetParcelTableIds());
          GetAllTables(doc.GetPointTableIds());
      private static void GetAllTables(ObjectIdCollection tableIDs)
          foreach (ObjectId alignmentTableId in tableIDs)
Do I miss anything?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
jhm_dac
I came to the same conclusion after trying to figure it out recently. Short of exploding the table to be able to extract information, I got stuck. Though someone with more API experience may have better insight.
norman.yuan
@soonhui wrote:
... Alas some other tables are available though, ...
Even you can get the objects of "other tables" by their ID, there is nothing more you can do: no table related properties/methods are exposed in the API.
Norman Yuan
Drive CAD With Code
BlackBox_
As evidenced by Project Explorer using vanilla AutoCAD Table with cell values that just get updated dynamically.
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
soonhui
Hi all, I've filed a case here at the ideas forum. Do consider give it an upvote!
Ngu Soon Hui
