Folder Selection Dialog Box - Resize
I recently created a lisp that will let me plot -> pdf my drawings. I got it to where I can manually select the folder I want the files saved each time, but the dialog box is a headache for me because I'm not able to resize it to see the everything.
With the basic dialog box for everything else, I can hover my mouse to the corner and resize it however I like, however with this default one after my lisp, I can't do the same.
SS 1 is the box with the lisp running.
SS 2 is the normal box if I were to plot it the default way.
and I've also attached my lisp for it to be looked at.
Is there something I can do to the lisp that will help with the dialog box issue?
Thanks.
Jeff_M
Unfortunately that dialog has the preset size which is not able to be changed.
Jeff_M, also a frequent Swamper
Yes, I got that. I was just seeing if there's a different way I can pdf my drawings a different way to where it uses a different dialog box.
