Flipping a line or curve label
DWCouch123YGV8K
DWCouch123YGV8K
I am creating line and curve label in LISP.  I then need to flip  some of them.  I can't seem to get the "fliplabel" command to work.
(setq SelObj (nentsel "\nSelect Line or Arc to Label: "))
I've tried each of these option.
Option 1  (setq sellbl (cdr (assoc 330 (entget (car selOBJ)))))
Option 2  (setq sellbl (entget (car selOBJ)))
(command "labelflip" sellbl)
I previously used setting the label property 'flipped to -1 but I can't seem to get that working.
(setq lastlabel (vlax-ename->vla-object (entlast)))
(vlax-put-property lastlabel 'flipped -1)
Working in C3D 2021
It's been almost 10 years since I have been doing this kind of thing (LISP programming).  I have forgotten a lot.
Jeff_M
Try this:
(vlax-put lastlabel 'flipped -1)
Jeff_M, also a frequent Swamper
DWCouch123YGV8K
I was sure I had tried that, but apparently not. It worked just fine.
Thank you Jeff.
