Find All Data Shortcuts with a .NET API
tipitasa
tipitasa
Is it possible to find all Data Shortcuts in the document?
I would like to get a list of all Data Shortcuts that includes Alignments, Surfaces, Pipe Networks, Pressure Networks and Corridors.
I know I can go group by group and traverse all entities in a group to find out which are references, like the below example for Surfaces.
Editor _ed = Application.DocumentManager.MdiActiveDocument.Editor;
CivilDocument _civilDoc = CivilApplication.ActiveDocument;
Database _db = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument.Database;
var surfaceIds = _civilDoc.GetSurfaceIds();
using (var tr = _db.TransactionManager.StartTransaction())
    foreach (ObjectId surfaceId in surfaceIds)
        var surf = tr.GetObject(surfaceId, OpenMode.ForRead) as Entity;
        if (surf.IsReferenceObject)
            var dsInfo = surf.GetReferenceInfo();
            _ed.WriteMessage("IsSourceDrawingExistent: " + dsInfo.IsSourceDrawingExistent + "\n");
            _ed.WriteMessage("SourceDrawing: " + dsInfo.SourceDrawing + "\n");
            _ed.WriteMessage("HandleHigh: " + dsInfo.HandleHigh + "\n");
            _ed.WriteMessage("HandleLow: " + dsInfo.HandleLow + "\n");
            _ed.WriteMessage("Type: " + dsInfo.Type + "\n");
    tr.Commit();
But this does not feel very efficient.
Is there a better way?
kevin.bza
Was this resolved? Using better terms may help. DS Referenced objects are DREF's or Data References. Hoping to get all DREF's from a DWG DB in one step instead of iterating Object ID Collections, one by one.
hosneyalaa
@tipitasa
maybe this help you
code python
import sys
import clr
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccDataShortcutMgd')
from Autodesk.Civil.DataShortcuts import *
from Autodesk.Civil.DataShortcuts import DataShortcutEntityType
vals = DataShortcuts.CreateDataShortcutManager(True)
dsm = vals[0]
c = dsm.GetPublishedItemsCount()
o = []
for i in range(c):
    p = dsm.GetPublishedItemAt(i)
    #pq = dsm.GetParentItemIndex(1)
    #o.append([p])
    if p.DSEntityType == DataShortcutEntityType.Alignment or p.DSEntityType == DataShortcutEntityType.Surface or p.DSEntityType == DataShortcutEntityType.PipeNetwork:
       o.append([p.Name , p.DSEntityType ])
    #o.append([p.Name , p.DSEntityType ])
OUT = o
