Extract ground points section to model or file like land does.
e_omairquliey
Message 1 of 26
e_omairquliey
Hallo guys i have problem that i can't extract the ground points section from civil 3d , i have searched the report section a lot of times and i couldn't extract them to model or file like land help me...
Accepted solutions (3)
Replies (25)
Message 21 of 26
TerryDotson
i need to extract the ground points which view in sample sections every 25 meters.
Try the attached points (DWG & XLSx files).
Message 22 of 26
e_omairquliey
I do know that order from future line but it's very difficult to arrange it in Excel.
as well as some stations there is no 0m offset for them.
I hope Autodesk solve this issue soon.
Message 23 of 26
e_omairquliey
I am v thankful for your help .
I will check the points with the ground section and i will back to tell you if they are correct.
Message 24 of 26
hosneyalaa
Maybe
Use this code And arrange it as you like
https://forums.autodesk.com/t5/civil-3d-customization/get-section-points-problem/m-p/6000784
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using aGi = Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
using Autodesk.Civil.ApplicationServices;
using Autodesk.Civil.DatabaseServices;
using CivDb = Autodesk.Civil.DatabaseServices;
namespace Extensions_Section
    public class Extensions_Section
        [CommandMethod("testExtensions_Section")]
        public void stExtensions_SectiondA()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            CivilDocument civdoc = CivilApplication.ActiveDocument;
            Editor ed = doc.Editor;
            PromptEntityOptions entOpts = new PromptEntityOptions("Select section:");
            entOpts.SetRejectMessage("...not a section, try again.");
            entOpts.AddAllowedClass(typeof(CivDb.Section), true);
            PromptEntityResult entRes = ed.GetEntity(entOpts);
            if (entRes.Status != PromptStatus.OK)
                return;
            using (Transaction tr = db.TransactionManager.StartTransaction())
                CivDb.Section sec = (CivDb.Section)entRes.ObjectId.GetObject(OpenMode.ForRead);
                var LL = sec.GetSectionLinks();
                var LLPOINT = sec.GetValidSectionPoints();
                tr.Commit();
    public static class ExtensionsSection
        public static IEnumerable<SectionPoint> GetValidSectionPoints(this CivDb.Section section)
            var valid = new HashSet<Point3d>();
            dynamic comSec = section.AcadObject; // AeccSection
            dynamic comLinks = comSec.Links; // AeccSectionLinks
            for (int i = 0; i < comLinks.Count; i++)
                dynamic comLink = comLinks.Item(i); // AeccSectionLink
                if (comLink.Type != 1)
                    valid.Add(new Point3d(comLink.StartPointX, comLink.StartPointY, comLink.StartPointZ));
                    valid.Add(new Point3d(comLink.EndPointX, comLink.EndPointY, comLink.EndPointZ));
            return (from sp in section.SectionPoints
                    where valid.Contains(sp.Location)
                    select sp);
        public static IEnumerable<Section.SectionLink> GetSectionLinks(this CivDb.Section section)
                var start = (from sp in section.SectionPoints
                             where sp.Location.IsEqualTo(new Point3d(comLink.StartPointX, comLink.StartPointY, comLink.StartPointZ))
                             select sp).First();
                var end = (from sp in section.SectionPoints
                           where sp.Location.IsEqualTo(new Point3d(comLink.EndPointX, comLink.EndPointY, comLink.EndPointZ))
                           select sp).First();
                if (start != null && end != null)
                    yield return new Section.SectionLink(start, end, i, comLink.Type);
        public static IEnumerable<Section.SectionLink> GetValidSectionLinks(this CivDb.Section section)
            return (from sl in section.GetSectionLinks()
                    where sl.Type != SectionLinkType.NoDraw
                    select sl);
    public static partial class Section
        public class SectionLink
            public SectionPoint StartPoint;
            public SectionPoint EndPoint;
            public readonly int Index;
            public readonly SectionLinkType Type;
            public SectionLink(SectionPoint startPoint, SectionPoint endPoint, int index, SectionLinkType type)
                StartPoint = startPoint;
                EndPoint = endPoint;
                Index = index;
                Type = type;
    public enum SectionLinkType
        None = 0, // aeccSectionLinkNone
        NoDraw = 1, // aeccSectionLinkNoDraw
        All = 2 // aeccSectionLinkAll
Message 25 of 26
e_omairquliey
Wow that is code to solve it. really amazing.
Where i can paste this code in lisp or visualbasic?
Message 26 of 26
hosneyalaa
