Export Civil 3D file to AutoCAD using .NET
darius.simkunas
darius.simkunas
I would like export to AutoCAD, Civil 3D drawing using API. How I can do this?
Thank you.
Best regards
Darius
augusto.goncalves
Hi Darius,
This Civl 3D UI feature is not exposed in the API, sorry. The closest you can get it's to recursively explode the Civil 3D entities and generate a basic DWG, also remove any Civil 3D specific entries from the dictionaries.
FYI, the "Export to AutoCAD" feature hook into the base DwgOut method of each entity, which is not easy to implement for a custom routine (addin).
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
