Descriptoin Key
Descriptoin Key
Descriptoin Key
Hi, we are updating fron LDD 2004 to Civil 3D 2012 needles to say it a huge change. I've got my template almost done I'm just having one problem. With LDD any point that came in with a raw descripitoin not within the description key it would be placed in the current layer with point number, descripton and elevation. How do I make that happen with Civil3D do I have to change my default lable settings? When I import points with a raw description not within my description key it places the point on Layer 0 and only shows the node no point number.
If this is not related to API / customization, would you mind posting at Civil 3D users group and I guess someone will have experience in this migration related issue.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/bd-p/66
Have you found a solution, yet?
Check your default point and label styles.  Once I fixed mine to be our company standard, it works just fine.  Otherwise, I was experiencing the same thing with just the node visible and nothing else.
