Custom Lisp Issue
Custom Lisp Issue
Krispm
Observer Observer
Custom Lisp Issue
Krispm
Observer
Observer
I have recently upgraded my license from 2020 to 2023. I have custom lisps for layer manipulation which are tied to a custom toolbar. I have support files (under options) pointed to the folder with lisp file. I have used the appload command, which once executed, all lisp files work. However, when I restart C3D, the toolbars load but lisps do not. I am using the default profile and cui.
Any help would be appreciated.
Thank you
Kris
andrewpuller3811
You need someway to load the lisps so that the commands within are recognised, either by adding them to the Startup suite in the appload dialogue, have a loader function in the menu files or acaddoc.lsp file or have the buttons run the appload command.
What is the command string the buttons are running?
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
Krispm
Observer
Observer
Thank you, I needed to load each lisp within the CUI.
