Creation of new Civil3D Assembly
Engr_Rod_D_Lecetivo_RMEE
A wonderful day everyone,
I am new to post here in the forum to seek for you guys expertise and new friend.
I would like to create a Civil3D assembly. In below, and would like it to adapt in relation to CANT. how can I achieve my preliminary goal?
Please advice me if there is a link which directly answer my concern.
Do we have in autodesk tutorial address this issue?
I have created a sample on subassembly composer. But only right side.
Can I create a set of left and right then drive it in superelevation?
Specifically, I want to CANT option:
1. edge A or B
2. Center
SoaresASBCAD
@Engr_Rod_D_Lecetivo_RMEE
Hello!
Yes, this is possible. The best approach is to create separate left and right subassemblies in Subassembly Composer and then control both using superelevation in Civil 3D.
To switch between:
  • Edge A;
  • Edge B;
  • Center;
you need to properly configure the “Axis of Rotation (AOR)” in the subassembly.
Usually this issue happens when the rotation pivot is fixed.
Try searching for:
Civil 3D Axis of Rotation
Lane Superelevation AOR
Subassembly Composer Superelevation
The Autodesk Subassembly Composer documentation also includes some superelevation examples that may help.
ASoares
