Creating profile from file
Message 1 of 22
Is there any way to call this command without the dialog box. it would be nice to get away from the file selection box by passing it as an argument to a lisp function. Even better if the following box Create Profile - Draw New  could be bypassed? Any thoughts ideas? I know LISP, so would prefer a LISP solution. I have no .net experience. But am willing to experiment if anyone can push me to a specific method available in the API? Thanks in advance.
Replies (21)
Message 2 of 22
Ranjit_Singh
AFAIK, activeX does not provide any method for this. Not sure about .net
Message 3 of 22
lu_an_jie
This is .net (c#) sample for creating a profile, based on two points.
        public static void CreateProfileNoSurface(Alignment oAlignment)
            CivilDocument civDoc = CivilApplication.ActiveDocument;
            using (Transaction ts = Application.DocumentManager.MdiActiveDocument.Database.TransactionManager.StartTransaction())
                // use the same layer as the alignment
                ObjectId layerId = oAlignment.LayerId;
                // get the standard style and label set
                // these calls will fail on templates without a style named "Standard"
                ObjectId styleId = civDoc.Styles.ProfileStyles["Standard"];
                ObjectId labelSetId = civDoc.Styles.LabelSetStyles.ProfileLabelSetStyles["Standard"];
                // create a new empty profile
                ObjectId oProfileId = Profile.CreateByLayout("MyProfile", oAlignment.Id, layerId, styleId, labelSetId);
                // Now add the entities that define the profile.
                Profile oProfile = ts.GetObject(oProfileId, OpenMode.ForRead) as Profile;
                Point2d startPoint = new Point2d(oAlignment.StartingStation, 40);
                Point2d endPoint = new Point2d(oAlignment.EndingStation, -70);
                ProfileTangent oTangent1 = oProfile.Entities.AddFixedTangent(startPoint, endPoint);
                ts.Commit();
You can enclose this in a while loop, reading and parsing the text file line and adding entity. You can find plenty of sample of reading and parsing text files in the AutoCAD development  forum.
https://forums.autodesk.com/t5/net/reading-data-from-a-txt-file-using-c/td-p/6005943
Regards
Andreas Luka (Lu An Jie)
http://www.luka-consult.de
Creator of the LX-Stair App for Civil 3D
Message 4 of 22
lu_an_jie
Do you have a sample file, so I can test some code.
Regards
Message 5 of 22
Jeff_M
Here's some code that shows how this can be done using lisp. You can take this as a starting point to create the function which accepts the file name, profile name, and profile style name. Hope it helps!
(vl-load-com)
(if (setq ss (ssget ":S" '((0 . "AECC_ALIGNMENT"))))
  (progn
    (setq alignment (vlax-ename->vla-object (ssname ss 0)))
    (setq profile (vlax-invoke (vlax-get alignment 'profiles) 'Add "NewProfileFromFile" 2 "Basic")) ;;the 2 is for a FinishGrade profile
    (setq pvis (vlax-get profile 'PVIs))
    (setq f (open "C:\\TestFiles\\Profiledata.txt" "r"));;this file must be in the format defined by C3D for profiles from a file
    (while (setq ln (read-line f))
      (setq data (str2list ln " "))
      (if (= 2 (length data))
	(setq pvi (vlax-invoke pvis 'add (atof (nth 0 data)) (atof (nth 1 data)) 1 nil nil));;the 1 tells C3D this a Tangent PVI
	(setq pvi (vlax-invoke pvis 'add (atof (nth 0 data)) (atof (nth 1 data)) 3 (atof (nth 2 data)) nil));;the 3 tells C3D it is a parabolic VC
    (close f)
;;;str2list by John Uhden, as posted to the adesk customization newsgroup a long time ago
(defun Str2List (str pat / i j n lst)
  (cond
    ((/= (type str)(type pat) 'STR))
    ((= str pat)'(""))
    (T
      (setq i 0 n (strlen pat))
      (while (setq j (vl-string-search pat str i))
        (setq lst (cons (substr str (1+ i)(- j i)) lst)
              i (+ j n)
      (reverse (cons (substr str (1+ i)) lst))
Jeff_M, also a frequent Swamper
Message 6 of 22
Awesome! This definitely gives me everything I need.Smiley Very Happy Thanks!!
Message 7 of 22
treforfjones
Hi Jeff
I came across your Lisp code with some surprise believing such manipulation of the civil
3d database wasn't possible, a bitter sweet moment, spent last six months learning vb.net.
First question should this still  work in Civil 3d 2018 and if so why does my lisp fall over at this ?
; error: Civil 3D API: The parameter is incorrect.
I presume it similar to the C# code
Any assistance will be greatly appreciated
Kind Regards
Trefor
Message 8 of 22
Jeff_M
Yes, Trefor, this should still be fine in C3D2018. Does your drawing have the profile style named Basic?
Message 9 of 22
treforfjones
Hi Jeff
Thanks for the prompt reply
I've enclosed a jpeg of the profile label sets in use ?
cheers
Trefor
Message 10 of 22
Ranjit_Singh
The "Basic" in @Jeff_Ms' code is referring to profile style and not label sets. Change the drop-down list above the tree view to either Active Drawing Settings View or Master View, and then look under Profile for the available styles and use one of those styles
Message 11 of 22
Jeff_M
@treforfjones,
The COM API arguments are as follows (from the help file): Profiles.Add(name, profile type, profile style), which is much different than the .NET API counterpart.
Message 12 of 22
treforfjones
Hi Jeff
Thanks that code is now working
Have you any similar lisp snippets that convert polylines to alignments
I've spent the last six months learning vb.net. Given your lisp experience
do you think C# is a better bet, long term to learn or
can I achieve a lot more with lisp  ?
cheers
Trefor
Message 13 of 22
Jeff_M
@treforfjones, lisp is limited for use with C3D. All of the API work since C3D 2012 has been for the .NET API. The COM API was last updated/added to in C3D 2012. I much prefer to use c# for .NET development...VB is something I decided to leave back in VBA.
I do still use lisp for small, quick, things, but anything that I want to be fast and powerful I use c#.
Message 14 of 22
lu_an_jie
It doesn't matter which programming language as long it is a .NET language (VB.NET, C# OR F# i.e.). You can even mix and match and creating different libraries in different languages in the same project as long you are targeting the same .NET framework.
In the Autodesk developer's documentation you can find all the sample code in VB.NET AS WELL AS IN C#.
Start with whichever language you feel more comfortable personally. The “language part” is something you can learn or re-learn in a matter of 1-3 days. What you are really learning here is the .NET: collections, interfaces, anonymous functions LINQ, MVC, XAML, WPF, Entity Framework and so on and so forth.
Here is the C# version for creating a polyline from a single alignment.
Here is same sample code, cha// (C) Copyright 2018 by Andreas Luka using System; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.EditorInput; using Autodesk.Civil.ApplicationServices; using Autodesk.Civil.DatabaseServices; // This line is not mandatory, but improves loading performances [assembly: CommandClass(typeof(LX_PolyLine.MyCommands))] namespace LX_PolyLine { public class MyCommands { // Modal Command with pickfirst selection [CommandMethod("MyGroup", "LX-Polyline", CommandFlags.Modal)] public void AlignToPoly() { // Getting the autodesk database (needed for transaction) Database db = Application.DocumentManager.MdiActiveDocument.Database; // Getting the editor object (needed for error messaging) Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; // Getting the civil document object (need for check of alignments presence) CivilDocument cd = CivilApplication.ActiveDocument; // Getting the list of all alignments in an collection of the ids ObjectIdCollection alignIds = cd.GetAlignmentIds(); // Getting out if there are no alignments in drawing if (alignIds.Count == 0) { ed.WriteMessage("\nNo alignments in drawing."); return; } // Calling function to select a single alignment ObjectId alignId = SelectAlignment(); // Getting out if the selection failes if (alignId == ObjectId.Null) return; // Getting the alignment from his id and creating the polyline using (Transaction tr = db.TransactionManager.StartTransaction()) { try { Alignment align = (Alignment)alignId.GetObject(OpenMode.ForRead); ObjectId plId = align.GetPolyline(); } catch { } tr.Commit(); } } // This function select an Alignment and returns his ObjectId or Null in case of Cancelation or Error public static ObjectId SelectAlignment() { Editor ed = Application.DocumentManager.MdiActiveDocument.Editor; // Setting ObjectId to Null ObjectId result = ObjectId.Null; // Creating the promt option for a single entity prompt PromptEntityOptions prOptions = new PromptEntityOptions("\nSelect alignment: "); prOptions.SetRejectMessage("...not an Alignment, try again!:"); prOptions.AddAllowedClass(typeof(Alignment), true); // Getting the selected element from the editor PromptEntityResult prResult = ed.GetEntity(prOptions); // Returning the selected alignment's id if (prResult.Status == PromptStatus.OK) result = prResult.ObjectId; return result; } } }
Regards
Message 15 of 22
hosneyalaa
HI @Jeff_M
God willing, your health is good
A question ...
I have a road profile
As it is in the picture or drawing
And I wrote in a file notebook
The STATION  AND LEVEL
OR
The STATION  AND LEVEL   AND  LENGTH
0 10.406
55 11 21.50
80 9.62 2.38
98.0 9.62
In order to draw it through
Creating profile from file ... Imported and profile drawn
But
When I use the code there is a problem
Could you please
What is the reason? Is writing notepad a mistake
Thank you in advance
http://www.mediafire.com/file/6qd5vtzgmobmlos/PROFILE+_++CIVIL+2021.dwg/file
Message 16 of 22
Jeff_M
@hosneyalaa  What problem are you seeing?
Message 17 of 22
hosneyalaa
@Jeff_M
Command: TEST
Select objects:
; error: AutoCAD.Application: Invalid input
Command:
(defun c:test ( / ALIGNMENT DATA F LN PROFILE PVI PVIS SS)
(vl-load-com)
  (progn
    (setq	FilePath (getfiled "Select TEXT file to read :"
			   (getvar "dwgprefix")
			   "txt"
			   4
    (setq f (open FilePath "r"));;this file must be in the format defined by C3D for profiles from a file
    (close f)
  (cond
    ((= str pat)'(""))
    (T
              i (+ j n)
0 10.406
55 11 21.50
80 9.62 2.38
98.0 9.62
Message 18 of 22
Jeff_M
@hosneyalaa Yes, there was an issue due to the vertical curves. You cannot have a VC without 2 tangents, which I did not account for. To solve this, I changed the code so it creates the first and last PVIs before adding the internal PVIs.
(defun c:test (/ ALIGNMENT F DATA LN PROFILE PVI PVIS SS)
  (vl-load-com)
    (progn
			       "txt"
			       4
      (if filepath
	(progn
	    (setq data (cons (str2list ln " ") data))
	  (close f)
	  (setq data (reverse data))
	  ;;create the first and last PVIs before adding the internal PVIs
	  (vlax-invoke pvis 'add (atof (nth 0 (car data))) (atof (nth 1 (car data))) 1 nil nil)
	  (vlax-invoke pvis 'add (atof (nth 0 (last data))) (atof (nth 1 (last data))) 1 nil nil)
	  (setq i 0)
	  (while (< (setq i (1+ i)) (- (length data) 1))
	    (setq d (nth i data))
	    (if (= 2 (length d))
	      (vlax-invoke pvis 'add (atof (nth 0 d)) (atof (nth 1 d)) 1 nil nil)
	      (vlax-invoke pvis 'add (atof (nth 0 d)) (atof (nth 1 d)) 3 (atof (nth 2 d)) nil)
  (cond
    ((/= (type str) (type pat) 'STR))
    ((= str pat) '(""))
    (T
     (setq i 0
	   n (strlen pat)
       (setq lst (cons (substr str (1+ i) (- j i)) lst)
	     i	 (+ j n)
Message 19 of 22
hosneyalaa
My teacher mister @Jeff_M
I am unable to thank you
You are a great person for this problem solving group
Thank you so much
Thank you so much
Thank you so much
Thank you so much
Thank you so much
Message 20 of 22
azhar_abbas9104ZVUC
VERTICAL FALL TOP AND BOTTOM ELEVATION ISSU
