Corridor creation in .net API
Dannyisrael
Dannyisrael
I have a big project that I'm setting the target through the API
I need to set the property “use target on the same side as subassembly”
To off .
I was expecting to find this property in the SubassemblyTargetInfo object
is there another place that I can change this property or change the default off the property
Dim myBaselineRegion As BaselineRegion
                myBaselineRegion = myBaseline.BaselineRegions.Add(BaseLineName, AssemblyName.AssemblyId, StartStation, EndStation)
                Dim myTargets As SubassemblyTargetInfoCollection = myBaselineRegion.GetTargets()
                myBaselineRegion.AppliedAssemblySetting.MODAlongCurves = 0.05
                myBaselineRegion.AppliedAssemblySetting.CorridorAlongCurvesOption = Autodesk.Civil.CorridorAlongCurveOption.CurveBoth
                myBaselineRegion.AppliedAssemblySetting.MODAlongTargetCurves = 0.02
                myBaselineRegion.AppliedAssemblySetting.FrequencyAlongCurves = 20
                myBaselineRegion.AppliedAssemblySetting.FrequencyAlongTangents = 20
                myBaselineRegion.AppliedAssemblySetting.FrequencyAlongSpirals = 20
                myBaselineRegion.AppliedAssemblySetting.AppliedAdjacentToOffsetTargetStartEnd = True
                myBaselineRegion.AppliedAssemblySetting.AppliedAtOffsetTargetGeometryPoints = True
                Dim t = AssemblyName.TargetIndex(myTargets)
                For Each b In AssemblyName.TargetsNameToIndex
                    If t.ContainsKey(b.Key) Then
                        Try
                            myTargets.Item(t.Item(b.Key)).TargetIds = Perent.GetBaselineTarget(ts, myAlignment.Name, Nothing, StartJunction, EndJunction, 0, b.Value)
I wanted to change this property here after I assign the target
                        Catch ex As System.Exception
                        End Try
                Next
                myBaselineRegion.SetTargets(myTargets)
Jeff_M
If that property is available, I've sure not been able to find it. So I've concluded that they did not expose it.
Jeff_M, also a frequent Swamper
Dannyisrael
Is there a way to change the default behavior in civil 3D or in the API
Jeff_M
Not that I know of, sorry.
Dannyisrael
Thank you
