Civil 3D Version in Windows Explorer
I posted this to my G+ circles, and we had a pretty active discussion, but no solution.
Back in the day, DWG TrueConnect added the Windows attributes of DWG Creator Name and DWG Creator Version. This worked fine in XP, but there doesn't appear to be a replacement for Win 7. Seth Hall, Being Civil contributor wrote about it here: http://beingcivil.typepad.com/my_weblog/2009/02/what-version-was-this-drawing-created-in.html
In Win 7, you can show the DWG version, but not the Civil 3D version. Since the objects aren't backwards compatible and many offices run multiple versions of Civil 3D, it's important to open the drawing in the version in which it was created. Has anyone out there written a tool that will show the Civil 3D version? JTB World proposed an app that would populate a custom field, but that would only populate the field when the drawing was opened, you could then see the version, and that would be with the version you open it with (which may not be correct). There was no ability to see any information about files that hadn't been opened with the add-on.
I see in the dwg header, opened with notepad, that there are AC# associated with the drawing, but I don't think it has anything to do with the Civil 3D version. There's got to be some coding somewhere.
