Civil 3D 2017 + Windows 10 debugging
Alexey.Terno
Message 1 of 22
Alexey.Terno
Hello everyone,
I can't debug my applications on Windows 10 with Civil 3D 2017. Debugging process always crash at acadmap.arx file loading.
In event log I have found appropriate error:
Faulting application name: acad.exe, version: 27.0.52.0, time stamp: 0x56b6cb23
Faulting module name: KERNELBASE.dll, version: 10.0.10586.103, time stamp: 0x56a8489c
Exception code: 0xe06d7363
Fault offset: 0x0000000000071f08
Faulting process id: 0x1e50
Faulting application start time: 0x01d19c174b49ec35
Faulting application path: C:\Program Files\Autodesk\AutoCAD Civil 3D 2017\AutoCAD 2017\acad.exe
Faulting module path: C:\Windows\system32\KERNELBASE.dll
Report Id: 98192d73-3007-4bbf-9c3c-53eb4f43a288
Faulting package full name:
Faulting package-relative application ID:
How can I debud applications on Win10?
Replies (21)
Message 21 of 22
TiStars
Hi denler,  I tried and it works! excellent !  thanks a lot!
but it is tricky for Chinese version, normally it will be map_cn.res, but it didn't work, I tried map_zh.res,  it worked!
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Message 22 of 22
TiStars
Hi Alexey, did you get your problem fixed? may be you can try denler's solution, it worked for me.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
