change default label style to a child style .NET
I am trying to change the default label styles for AddSegmentLabel under general styles using .NET...
Dim X As Autodesk.Civil.Settings.SettingsCmdAddSegmentLabel = CD.Settings.GetSettings(Of Autodesk.Civil.Settings.SettingsCmdAddSegmentLabel)()
X.Styles.LineLabel.Value = strChildStyleName ... says name does not exist
or
X.Styles.LineLabelStyleId.Value = oidChildStyle ... "The type of objectId is wrong"
If I manually change it to a child style and then check the values, they are the same as what I'm trying to set them to. If you use a "parent" style then these both work. Am I doing something wrong or this another limitation?
Jeff_M
It seems as though we aren't permitted to work with Children. I have seen other cases where Child styles throw exceptions and was told that the code was working 'as designed'...meaning it wasn't implemented for whatever reason.
Jeff_M, also a frequent Swamper
