Block Text to be oriented as per layout
Engr_Rod_D_Lecetivo_RMEE
I have an alignment.
then I converted or create a AutoCAD file.
Let say I divided it in segments Straight, Spiral Curve,
Then I created a block.
In this block there are attribute tags.
I want my block rotation to be the same as I rotated it in the model.
But  I want my attribute tag to be rotated as per layout automatically.
Right now I am using rotate parameter in block to rotate each tags of blocks which is kinda time consuming.
I want to automate it in some ways. Maybe there is available command or tricks available in the latest AutoCAD version.
I would like to know.
Sorry for being not clear and confusing. Lets focus on the block with tag.
No matter what the orientation of it. It is the same orientation in the layout. Except for its attribute tag.
If you guys have any idea. Please let me know.
My highest regards,
Rod Domagsang Lecetivo
PS. I have read the post  here.
1. https://forums.autodesk.com/t5/autocad-forum/keep-block-text-horizontal-while-rotating-a-block/td-p/...
2. https://forums.autodesk.com/t5/autocad-electrical-forum/changing-attribute-text-styles/td-p/6625863#....
They change text style and it should affect text using it regardless if it is attribute or not.
I tried but not working on Civil3D layout not sure why. If there is wrong with my method or anything.
essam-salah
hi@Engr_Rod_D_Lecetivo_RMEE
the process isn't clear, do you mean you have used the Alignment as Path for a Autocad Array-Path?, anyway if you have a block and wanted to place it repeatidly on an Alignment as an alignment label you can use any Alignment label that contains block (like station with tick) and replate the block ( the tick component in case of station with label) with your custom block,
Thank you for your reply. I have added a new image above. Sorry for my late reply and thank you for your time.
