Best Way to Programmatically Identify a Coordinate System?
CodeDing
Advisor Advisor
CodeDing
Hey all,
Looking for some guidance here. The overarching question is:
What is the best way to programmatically identify a coordinate system?
I understand that there are Projected, Geodetic, Arbitrary, etc ...Coordinate Systems. So perhaps for sake of taking a first step, the question could be:
What is the best way to programmatically identify a projected coordinate system?
It should also be assumed that enough information necessary to identify the coordinate system is present (e.g. Ellipsoid name/flattening/radius/etc, Projection scale/false northing/false easting/etc, Datum name/realization/etc). Also, the data can be in any format necessary (JSON, XML, WKT, etc).
So even if I have all of this data, HOW can I programmatically (using any programming language, ideally .NET or Python) output, with ##% confidence, something like:
- EPSG 2232
- Custom CS, based on EPSG 2232
- Arbitrary CS
I would like to ultimately retrieve this information from a source, open Civil 3D, and automatically assign a coordinate system (assuming I have sufficient information/confidence to do so).
As always, any input is appreciated.
Best,
~DD
rampseeker
I retrieve the coordinate system code using this method
[CommandMethod ("printCoordinate")]
public static void PrintCoordinateSystemCode()
    var doc = Application.DocumentManager.MdiActiveDocument;
    var ed = doc.Editor;
    var civDoc = CivilApplication.ActiveDocument;
    // getCoordinateSystemCode
    string csCode = civDoc.Settings
                            .DrawingSettings
                            .UnitZoneSettings
                            .CoordinateSystemCode;
    if (string.IsNullOrEmpty(csCode))
        ed.WriteMessage("\nNo coordinate system is set for this drawing.");
    else
        ed.WriteMessage($"\nCurrent coordinate system code: {csCode}");
CodeDing
@rampseeker ,
Thanks for the reply! I can easily get the CS Code with the System Variable CGEOCS. My main goal is rather identifying a system by all of it's definition properties. In essence, if I had everything BUT the CGEOCS code, how would I determine a CGEOCS code lol
Best,
~DD
Anton_Huizinga
You can request the current Coordinate System with this code:
        public static acDbServ.GeoCoordinateSystem GetCurrentCoordinateSystem()
            acDbServ.GeoCoordinateSystem returnValue = null;
            string name = string.Empty;
            acDbServ.Database db = acAppServ.Application.DocumentManager.MdiActiveDocument.Database;
            using (acDbServ.Transaction tr = db.TransactionManager.StartTransaction())
                try
                    if (db.GeoDataObject != acDbServ.ObjectId.Null)
                        acDbServ.GeoLocationData gd = tr.GetObject(db.GeoDataObject, acDbServ.OpenMode.ForRead) as acDbServ.GeoLocationData;
                        Match matchName = Regex.Match(gd.CoordinateSystem, "<Name>(.*?)</Name>");
                        if (matchName.Success)
                            name = matchName.Groups[1].Value;
                        if (name != string.Empty)
                            foreach (acDbServ.GeoCoordinateSystem cs in acDbServ.GeoCoordinateSystem.CreateAll())
                                if (cs.ID == name)
                                    returnValue = cs;
                                    break;
                catch (System.Exception ex) { }
                tr.Commit();
            return returnValue;
The returned object can be read further, if I remember correctly, you can see if it is projected and read the WKT stuff and so on.
If you want all 6000+ available Coordinate Systems, you can use this code:
       public static List<acDbServ.GeoCoordinateSystem> GetAllValidCoordinateSystems()
            List<acDbServ.GeoCoordinateSystem> returnValue = new List<acDbServ.GeoCoordinateSystem>();
            List<string> ignoreItems = new List<string>() { "obsolete", "deprecated", "replaced by", "for testing only", "incorrect", "legacy use" };
                if (cs.Type == acDbServ.GeoCSType.Projected)
                    string description = cs.Description.Trim().ToLower();
                    if (ignoreItems.Any(s => description.Contains(s)) == false) { returnValue.Add(cs); }
            return returnValue;
CodeDing
@Anton_Huizinga ,
That's useful information! I'm semi familiar with retrieving the CS Dictionary XML data. Perhaps this would be one step of the entire process. But my question would still remain:
If I had everything BUT the CGEOCS code, how would I determine a CGEOCS code?
It's a very nuanced question and definitely not easy to answer.
Best,
~DD
Anton_Huizinga
I guess you could walk through all available CS and then compare as many as values.
