append text to label
Yonas89
Message 1 of 15
Yonas89
I am trying to append text to my profile view label, which has  been just created. I have found text override example on the internet which also works in my case, however I don't want to override my label text completely, I just want to append additional text before  by label value. What should I do different? Thanks!
Here is a clip from my code:
ProfileViewDepthLabel.Create(PV.ObjectId, IdLabelStyle, pt1, pt2)
                    Dim lastEntity As ObjectId = Autodesk.AutoCAD.Internal.Utils.EntLast()
                    Dim DPLabel As ProfileViewDepthLabel = tr.GetObject(lastEntity, OpenMode.ForWrite)
                    DPLabel.SetTextComponentOverride(DPLabel.GetTextComponentIds(0), "Override", Autodesk.Civil.TextJustificationType.Left)
Replies (14)
Message 2 of 15
Jeff_M
Use the GetTextComponentOverride() method and add your text to the result.
Also, no need to use the EntLast method. Just do this:
Dim lastEntity As ObjectId = ProfileViewDepthLabel.Create(PV.ObjectId, IdLabelStyle, pt1, pt2)
Jeff_M, also a frequent Swamper
Message 3 of 15
Yonas89
Thanks for your reply Jeff!
However I am still struggling...
should i delete SetTextComponentOverride()?
Message 4 of 15
Jeff_M
No, get the current override, add your text to that, use the SetTextComponentOverride to add the combined text back to the label. Something like this...I don't normally use VB so this may not be exactly correct.
Dim str as String = DPLabel.GetTextComponentOverride(DPLabel.GetTextComponentIds(0)) DPLabel.SetTextComponentOverride(DPLabel.GetTextComponentIds(0), "Override:" + str)
Message 5 of 15
Yonas89
Thanks a lot!
Message 6 of 15
Yonas89
Also, I face some further problem, as an "override" text appears in different text style. How to match these text styles?
Thank you very much in advance!
Message 7 of 15
Jeff_M
A more specific description, along with a drawing and your code, would sure help in this. As I'm not quite sure what you are asking...
Message 8 of 15
Yonas89
Well now I got this which works just fine.
                    Dim MDepthLb As ObjectId = ProfileViewDepthLabel.Create(PV.ObjectId, IdLabelStyle, pt1, pt2)
                    Dim DPLabel As ProfileViewDepthLabel = tr.GetObject(MDepthLb, OpenMode.ForWrite)
                    Dim DPLabelstr As String = DPLabel.GetTextComponentOverride(DPLabel.GetTextComponentIds(0))
                    DPLabel.SetTextComponentOverride(DPLabel.GetTextComponentIds(0), "override" + DPLabelstr)
But the text font and height of DPLabestr and "override" are different. Seems that the "override" string is using standart text style and default height.
I need to get text style of DPLabel text component somehow but cannot achieve this.
Message 9 of 15
Jeff_M
Have you changed the style/font used for the textcomponent to be different than what the Style's General settings specify? Check the value returned by the GetTextComponentOverride. If it has font/textstyle information included then you will have to do additional string parsing.
Message 10 of 15
Yonas89
Thanks for the tip, however no luck yet. I am not able to extract font/textstyle from GetTextComponentOverride.
Message 11 of 15
Jeff_M
Can you post a drawing that you've edited with the code above?
Message 12 of 15
Yonas89
My code basically puts depth labels along profile. You can see it in the drawing. I override  depth labels with  "-" sign where design profile is lower than compared profile.
Message 13 of 15
Jeff_M
OK, I see what you mean. I'm swamped today, will try to find a resolution as soon as I get a break.
Message 14 of 15
Yonas89
Thanks, Jeff
Message 15 of 15
Yonas89
Jeff, I have found the problem why my appended text was  in the different font. My label text style under general tab was left as Standart. This was a problem. I have changed this font now the minus sign appears in correct font. Thanks a lot for your help!
