Add a breakline to an existing surface using LISP
blair.nixon
Message 1 of 14
blair.nixon
How would I add a standard breakline (3D polyline) to an existing surface using visual LISP? I would like to use LISP in this case and not .NET.
Thanks in advance.
Replies (13)
Message 2 of 14
hosneyalaa
Message 3 of 14
blair.nixon
I've seen that doc already but am looking for an example, if available?
Message 4 of 14
Jeff_M
Here is an example to add a Wall breakline, refer to the help for other types.
(defun c:test_AddWallBreakline  ( / *ACAD* ALGN BLKSOBJ C3D C3DDOC DOC ENT E_TYP OBENT PNTS SPC SRF XSTTY)
  (vl-load-com)
  (defun makevariant (vtype listvalue / )
    (setq array (vlax-make-variant listvalue))
    (setq sa (vlax-make-safearray  (vlax-variant-type array) (cons 0 0)))
    (vlax-safearray-fill sa (list array))
    sa
  (IF     (OR
	    (setq algn (vlax-ename->vla-object (setq lw(car (entsel "\nSelect Polyline: ")))))
	    (while (not (= (vlax-get-property algn 'ObjectName) "AcDbPolyline"))
	      (setq algn (vlax-ename->vla-object (car (entsel "\nSelect Polyline: "))))
    (PROGN
      (setq srf (vlax-ename->vla-object (setq ent (car (entsel "\nSelect Surface: ")))))
      (while (not (= (vlax-get-property srf 'ObjectName) "AeccDbSurfaceTin"))
	(setq srf (vlax-ename->vla-object (car (entsel "\nEntity must be C3D Surface. Try again: "))))
      (setq breaks (vlax-get srf 'Breaklines))
      ;;http://docs.autodesk.com/CIV3D/2012/ENU/API_Reference_Guide/com/AeccXLandLib__IAeccSurfaceBreaklines__AddWallBreakline@[in]_VARIANT@[in]_BSTR@[in]_double@[in]_VARIANT@[in]_VARIANT@[out,_retval]_IAeccSurfaceBreakline___.htm
      (vlax-invoke-method
	breaks
	'AddWallBreakline
	(makevariant nil algn)
	(vlax-get-property algn 'HANDLE)
	0.1
	(makevariant vlax-vbdouble  1.0) ;;LEVEL
	(makevariant vlax-vbboolean 1) ;;LEVEL
  (princ)
Jeff_M, also a frequent Swamper
Message 5 of 14
blair.nixon
That was exactly what I needed!
I was missing/not understanding how to select a polyline and turn it into a variant.
Thank you so much!
Message 6 of 14
hosneyalaa
HI @Jeff_M
THANT YOU FOR  an example to add a Wall breakline
But
When I tried it it didn't work An error appeared with me
can you take a look
Command: TEST_ADDWALLBREAKLINE
Select Polyline:
Select Surface: ; error: Automation Error. Description was not provided.
Message 7 of 14
Jeff_M
@hosneyalaa yes, I am seeing the same thing. This is something I wrote years ago and I did not test it prior to posting yesterday. It's been long enough ago that I don't recall if it ever worked. I've just tried a number of things to get it working, none have been successful. When I get some more time I will try again.
Message 8 of 14
blair.nixon
I was looking for a standard breakline and not a wall breakline so I revised the code Jeff posted (if this helps at all).
(defun c:AddSurface (/ surfname brkline C3D verstring prodstring datastr surfs tincreationdata srf breaks)
(setq surfname (getstring 1 "\nEnter surface name = "))
(setq brkline (vlax-ename->vla-object (setq lw(car (entsel "\nSelect Polyline: ")))))
(setq C3D (strcat "HKEY_LOCAL_MACHINE\\" (if vlax-user-product-key (vlax-user-product-key) (vlax-product-key)))
C3D (vl-registry-read C3D "Release")
verstring (substr C3D 1 (vl-string-search "." C3D (+ (vl-string-search "." C3D) 1)))
prodstring (strcat "AeccXUiLand.AeccApplication." verstring)
(setq datastr (strcat "AeccXLand.AeccTinCreationData." verstring))
(if (and (setq *acad* (vlax-get-acad-object))
(setq C3D (vla-getinterfaceobject *acad* prodstring))
(setq C3Ddoc (vla-get-activedocument C3D))
(setq surfs (vlax-get C3Ddoc 'surfaces))
(setq tincreationdata (vla-getinterfaceobject *acad* datastr))
(progn
(vlax-put tincreationdata 'baselayer "0")
(vlax-put tincreationdata 'layer "0")
(vlax-put tincreationdata 'description "Surface Created by LISP")
(vlax-put tincreationdata 'name surfname)
(if (wcmatch (strcase surfname) "*BASE*")
(vlax-put tincreationdata 'style "_No Display")
(vlax-put tincreationdata 'style "Contours and Triangles")
(setq srf (vlax-invoke-method surfs 'addtinsurface tincreationdata))
(vlax-invoke-method
breaks
'AddStandardBreakline
(makevariant nil brkline)
(vlax-get-property brkline 'HANDLE)
0.1
;add boundary
(vlax-invoke (vlax-get srf 'boundaries) 'add brkline "Created by LISP" 4 :vlax-TRUE 0.05)
;rebuild surface
(vlax-invoke-method srf 'rebuild)
(princ)
Message 9 of 14
john.uhden
@Jeff_M
Unlike you, who has advanced to higher lever programming languages, I am forever stuck in AutoLisp, mostly resulting from my days of customizing Land Desktop.
But I am proud that I finally included filtering for raw descriptions in the 6th version of my breakline.lsp program for Civil 3D.  You select one or more 2D or LW polylines (which you have already drawn), provide a layer filter and/or description filter and it creates 3D polylines with vertices added between points on curves.  It makes my life so much easier to create separate breaklines for TC vs. G (or as they use here, BC) when they are right next to one another.  I should probably shrink it by removing all the LDT specific code, but I think maybe if it works, don't fix it.
John F. Uhden
Message 10 of 14
artirtas9100
Hi all,
I would like to add a selection set of polylines (i've hundreds of them...) per layer as one breakline entry in the Surface Definition/Breaklines.
How do i do that?
I have this so far (changed from the code by blair.nixon):
(setq algnset (ssget "_X" '((0 . "POLYLINE") (8 . "Layername-10") ))) ;; select alle poly-objects on a layer
(setq newset (LM:ss->vla algnset)) ;; convert to VLA objects, thank you Lee Mac
(vlax-invoke-method
breaks
(makevariant nil newset) ;; to be replaced with a variant of the selection list... but how to do it?
"BL-Layername-10 (added via lisp)"
0.1
But I get this error:
error: lisp value has no coercion to VARIANT with this type: (#<VLA-OBJECT IAcad3DPolyline 0000028b11cb0da8> #<VLA-OBJECT IAcadLWPolyline 0000028b54b185e8>
(the same error when you just use newset with makevariant function)
In Civil3D's GUI (2022) you can do this of course but would like to automate it with lisp.
Can somebody shine a light on this?
Thanks in advance!
Message 11 of 14
hosneyalaa
@artirtas9100
Can you attached example drawing for testing
Message 12 of 14
artirtas9100
Very basic dwg for testing (not a production dwg with hundreds of poly's...)
Message 13 of 14
Jeff_M
@artirtas9100 here is a lisp that asks you to select the surface then select a polyline on the layer containing polylines. It will then get all polylines on that layer and add them as a single breakline set to the selected surface.
(defun c:AddBreaklines2Surface (/ brkline brklines srf breaks ss->array)
  ;; the following function from the AutoCAD Expert's Visual Lisp book
  ;; by Reinaldo N. Togores
  ;; http://lispexpert.blogspot.com/p/blog-page_94.html
  (defun ss->array (sel-set / index array)
    (setq index	0
	  array	(vlax-make-safearray
		  vlax-vbObject
		  (cons 0 (1- (sslength sel-set)))
    (repeat (sslength sel-set)
      (vlax-safearray-put-element
	array
	index
	(vlax-ename->vla-object (ssname sel-set index))
      (setq index (1+ index))
    (vlax-make-variant array)
	      (ssname (ssget "_:S+." '((0 . "AECC_TIN_SURFACE"))) 0)
		   (setq lw
			  (car (entsel
				 "\nSelect Polyline on layer with breaklines: "
	brklines (ss->array (ssget "X"
				   (list '(0 . "*POLYLINE*")
					 (cons 8 (vla-get-layer brkline))
  (vlax-invoke-method
    breaks 'AddStandardBreakline brklines (strcat "added from layer: " (vla-get-layer brkline))  0.1)
					;rebuild surface
  (princ)
Message 14 of 14
artirtas9100
Jeff,
that ss->array function is a gem... This works great! I would never have found this.
Hopefully I've now the necessary stuff to do something similar with points.
Many thanks for your efforts (and the entire lisp)!
