A well documented API SDK help for Civil3D.
Please share a link from where I can download a well documented API SDK help for Civil3D. This should have the list of all APIs and their description. I also want class hierarchy and dependencies.
augusto.goncalves
Take a look at the Developer Center: http://www.autodesk.com/developcivil
And the Reference Guide at http://docs.autodesk.com/CIV3D/2016/ENU/API_Reference_Guide/
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Thank you for your quick response.
I would like to get the help which lists all the APIs available.
Viz. Please refer attached "Corridor class.png". Where can I get the list and description of each and every API method available in .NET application for "class Corridor : Entity"
I couldn't find any of the APIs and their description for object of type "class Corridor : Entity". Both links you mentioned do not give this information.
Note: Can I get download link for a offline help?
Please guide me where I can get this information.
Thanking you in advance for all your help.
Jeff_M
I do not believe that the .NET API docs are available for offline use.
The .NET API Reference includes the Corridor entity:
http://docs.autodesk.com/CIV3D/2017/ENU/API_Reference_Guide/html/d9844328-946f-1332-132e-c86d6530466...
The second link in Augusto's post will get you to the top of the reference guide, which DOES include this information.
Jeff_M, also a frequent Swamper
Thank you. I got the necessary information.
