I keep getting this error message. What do I need to set up to fix it?
Yiannis.
Hi @Anonymous
Thanks for your post. ![]()
Could you please try logging in and using Character Generator now?
The development team informed me that any login issues or errors should be resolved now. From my testing a few moments ago, I was able to log into my account and use it without errors. ![]()
Thank you!
Hi @Anonymous, thanks for the follow-up. ![]()
The original issue was resolved by the development team concerning errors when customizing new/current characters.
Are you still experiencing errors while creating new characters or customizing current ones?
If so, could you please try clearing your current Internet browser cache:
The error still remains. It's impossible to log in. All my work is unaccessible.
Can you please help me? Please fix this.
When you hit the error, refresh the window and sign in again, you will then access the software. There is a timing issue with authentication, the login has worked buy displays this error. Press refresh and press sign in again you will then be able to proceed.
To fix the "Constant error in Character Creator," start by ensuring that the software and any related programs are updated to their latest versions and that your system meets all required specifications. You can also try resetting the software's preferences to default or reinstalling it if the problem persists. If these steps don't resolve the issue, consider reaching out to official support or checking forums for additional troubleshooting advice.
If you’re encountering a constant error in Character Creator, it’s likely due to a miss configuration or missing component. First, ensure that your software is up to date and that all necessary plugins or add-on are properly installed. If the issue persists, try resetting the software settings to default or reinstalling the application. For more troubleshooting tips.
