I'm using Autodesk Characters in Unity for a research project on how facial expressions are perceived in VR. So far I could create some pretty realistic facial expressions like smiling, fearful face etc. However, when I try using the "open mouth" blendshape, the lips do form in the expected manner but the teeth keep touching instead of opening.
How can I actually open a character's mouth in Unity?
Marius
I am sorry, I am not a Unity expert. My knowledge of Unity is basic
... but If you load a CGen character in Unity that was exported using Facial Blend Shapes expression, you can probably create a script that will for example set the teeth_Shout "blend shape" (open mouth) parameter to 100 when the expression.Shout is set to 100.
* See the attached file
Best regards
Sophie
thanks for the file. I've tried setting expression.Shout to 100. It does form the lips in a shout-like-manner. However, the mouth itself won't open. I've attached an image of what that looks like.
Anyone knows a solution?
Best,
Marius
Like I said, you also need to set the teeth_shout to 100
Select the teeth and then set the teeth_shout parameter to 100.
Best regards
Sophie
